Foggy Rear Window Issue?
Wire4money
Las Vegas
2005 Wrangler
In many years of owning trucks of almost all manufacturers, I’ve never used a rear window defogger. Like mentioned, make sure the hvac is not on recirc.
  • Like
Reactions: Dad
OleFordGuy
Ha, those replies reminded me of the Titanic movie scene....no clue why.
Ford Maverick Foggy Rear Window Issue? titanic
MAVERICK8011
BOB
Rosedale, maryland
www.yahoo.com
Maveruck
Yes, open the vent to let air in to recirculate. If that doesn't you are breathing to heavy.
TdotMav
Toronto
Acura MDX
I’ve never had much of a problem over a year in Michigan winter. I would also recommend as others have rainx (& similar products) but just like having a full load in the bed you can’t see out back so use your mirrors, etc.
My order has rear sliding window. I heard you can't do rainx with rear sliding window. Any other options for aftermarket rear defroster?
paneubert
Seattle
Why not? Only reason I could see would be some claim about the window sliding open and closed rubbing off the coating prematurely. Which wouldn't be a reason to not use Rain X. Just means you have to reapply more often.
Deadangels84
Pennsylvania
Ford Maverick Lariat
Frost Fighter actually makes an aftermarket kit for the rear windshield... don't know how much of a pain it is to install or how well it works. Saw it on another forum.
Jmav2152
Jamie
Cleveland, OH
You have a back up camera and side mirrors until the cab gets warmed up. You'll be fine.
Joe Kelly
St Charles, Mo
1973 Triumph TR-6, 2009 Accord, 2017 Pacifica
I had watched a Youtube video (cannot recall who made it) but with several people seated in the Maverick they had issues dealing with a foggy rear window.
I just wanted to know if this is a legitimate issue or nothing to worry about.
Thanks! :)
Do not use the recycle setting on the heat and A/C on rainy or snowing days. You can crack a window to relieve the issue
Mabcim
Rochester, NY
I’ve looked into that. They only say it can go on a window without any opening.
I‘ve looked at F150 with a slider and factory defroster, there are thicker lines on the sides. Seems a more complicated routing, then they say they support, is needed. Probably if the lines are too short, they will get too hot. Probably a way to figure it out, but then would need to figure out how to get power on the open section of glass; I have not looked inside an F150 to see how the factory does that.
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
VicRattlehead
Mokena
Couple ford cars and a truck
With the amount of ice we had the other day the truck still had ice on everything after I got home from my 30+ minute drive. So yeah that’s not tha answer.
used to use the center high mount vents aimed to the back on my ranger that worked but Maverick vents are so low it doesn’t get back there as easily. Love the defogger on my f150 but use it sparingly due to the window shattering issue they seem to have. 🤦🏼‍♂️ camera sucks it gets filthy in the matter of seconds.
