Window issue - rear passenger window will not go up
jmchap83
james
iowa
chevy truck
My right rear passenger window will not go up. 2023 hybrid
Scheduled to be in the shop this Thursday.
Who else has had this issue?
What was the problem?
Ford Motor Company
Official Ford Account
Dearborn, mi
Could you please send over a private message with your VIN and the name/location of your local Ford dealer? I would like to see what I can do to assist with your window issues!
fossil
ernie
ohio
a known issue with some, most common fix is replacing the drivers door switch module.
Montana
Any idea what the actual issue is? Is it the modules or are they being supplied too much voltage and just burning out?
Hillbilly
E. TN.
22 XL
Where would TOO much voltage come from? The wind turbine?
fossil
ernie
ohio
no informed idea. I wouldn't suspect high voltage with only the right rear failing.
fossil
ernie
ohio
Hcopter
KS
1996 Ranger, 2023 Maverick Lariat, Hybrid
I think I saw someone mention that it was stuck contacts in the driver's door, window switch. So if you used the drivers switch to roll the window down then it sticks like you're holding the button down continuously. Some light banging with your fist to the windows switch area may free the contacts.
MM Mav
Amy
Great Lakes Region
jmchap83
james
iowa
chevy truck
Thanks!
fossil
ernie
ohio
wow Amy, good search job, two more than I found.
I'll post any of my questions directly to @MM Mav :cool:
