Fog lights for Maverick ?
ADSkinner
Rochester, NY
Subaru Crosstrek
Seems like the soon to be released brackets (by Justin.23) is attached to a non-FX4 maverick, with hooks added after the fact. Anyone have an opinion on using the brackets on a native FX4? Will the integrity that the native tow hooks had be lost?
can't say I have looked under there you see if they were attached any differently.
KSC Grey Ghost
Tn
Jeep
Now that looks great nice and clean not a big over bearing light tucked in very nice . With respect I may copy your idea but put both clear and amber on my Maverick. . May I ask how you mounted the light s ?? Again very nice 👍😊👻
dddinstructor
Hiram
Honolulu, Hawaii
XLT FWD, 2.0L Ecoboost Engine, 8-spd Automatic
Believe it or not, these lights are the perfect sized to mount onto the vertical rods that support the lower grill. They were essentially "zip tied" tightly to a vertical rod at each end of the light.
The wires were fed through the lower bumper and up into the engine bay. You have to drill a 3/8" diameter hole at either end of the grill frame, which was easy. I power tapped fuse number 3 in the under the passenger dash board. I'll try to take some close ups of the install.
Timothyd
Hi
Does anyone have any ideas on what option may be available to install fog lights to the maverick.
Early morning drive (fog) for work really wished it was an option to have
Thanks
I'm putting on fog lights and aiming them for those that put fog lights on when there isn't fog.
jewc75
There is a difference in driving lights and fog. Fog lights aren't white. 🤐
jalbano2
JAMES
NY
2022 Maverick Lariat Lux, EB , 4k , FX4 , Moonroof
Waterick
Laurens county SC
That is what I always thought too. But then most OEM aux lights are supposedly fog lights and usually white. I think the real difference is in the lens and focal point.
Ren E Gade
24 Atlas Blue, BAP, Lariat
Just a heads up if you are planing on adding tow hooks I saw a video showing the inner structure to actually mount the hooks is not present if it was not equipped... do your own research.
