- First Name
- James
- Aug 10, 2026
- port orchard wa
- 2022 ford mavrick
- Engine
- 2.0L EcoBoost
We came out a few days ago and found the carpet on the drivers side foot well was completely soaked. When we got in it sounded like you were walking on a splash pad. I used my carpet shampooer and removed about 1/2 gal of water/fluid. I don’t think it is coolant it was not slimy and was clear. Took it into the dealer as it should still be under warrant, but they said it is likely the condensate drain but I order to confirm they would need to remove the dash and that would be 9 hours of labor that is not warranty work if it is a clogged condensation drain. Does this seem right why would you need to remove the dash I order to get to the condenser drain and if you do need to do all that work how would debris get into it to clog it?
