Floor jack
inferno
Ron
2009 Chevy Colorado, 2022 Ford Maverick
I hope this isn't a stupid question but I am wanting to jack up my Maverick with a floor jack. I have looked at the owners manual and looked under the truck but not sure what to use as a jacking point. I have never owned a unibody vehicle, only trucks with frames. The little arrows underneath make it look like you would jack at the pinch weld but just not sure if I can do that with a regular floor jack. Hoping to jack one side at a time with 2 jacks to remove both wheels. TIA
The Weatherman
Dean
KY
If your floor jack doesn’t have notches for the pinch weld to slip into it will likely crush that area over and break the paint bond at that point.
STARCOMMTREY1
Trey
Boligee, AL
Just stick a 2x4 on the top of the jack and you are good as gold.
Big_T
T
2022 Maverick XL Hybrid
You need something like this from Amazon LINK or a hockey puck with a slot in it.
STARCOMMTREY1
Trey
Boligee, AL
Well just shit all over my redneck fix why dont ya!!!!!!!
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
Big_T
T
STARCOMMTREY1
Trey
Boligee, AL
Well I guess you could cut a slot in yer 2x4....
Nah....the 2x4 distributes weight and actually puts less pressure on any one part. FWIW however, my wifes car has that and my floor jack has done zero damage to it. It was actually worse with her flimsy factory one that slipped and did not let go.
Rodeoman74
Casey
Milliken, Co
2022 Maverick 2.0l Lariat
I had used a piece of wood without issuešŸ‘. I might look at some ramps as an option moving forward.
notfast
Los Angeles CA
You are correct. Typically there will be arrows indicating where on the pinch weld it's safe to lift. The indicated area is usually reinforced or sometimes even has a "step down" portion that is slightly but noticeably lower and/or wider/thicker than the rest of the pinch weld.
If your floor jack doesn't have a rubber pad on it, you can use a block of wood or a hockey puck as others have said.
I prefer ramps for anything that doesn't require pulling the wheels off. I found it to be faster and you don't have as much crawling around on the floor.
I use the Rhino Ramps 12k that are commonly sold at Home Depot/Auto Zone/Walmart/Tractor Supply etc. I prefer them since they nest into each other for storage unlike the ones from Harbor Freight.
Maverick#
Kevin
Hinton AB
2023 XLT/ Maverick
Thanks for the ideas i am thinking of of using a bottle jack instead of the jack that comes with truck i have had a couple screw jacks in other vehicles and they both bent on me. Plus i do have a floor jack for at home.
Montana
Yep, got a 3 ton from Harbor Freight that I keep in the bed cubby and a pinch weld adapter that fits over it.
Kenv24
Ken
2024 XLT
If you don’t have wood or a puck, you can put the floor jack right on the marks. it’s not gonna bend the metal in those spots. I’ve done it a ton of times. 3 tons of times to be exact. šŸ˜‚šŸ˜‚šŸ˜‚
jphaymond
Louisville, KY
2025 Maverick
I’ve used a floor jack on my 20 yo BMW with no issues.
Haven’t tried it yet with the Maverick, but the lift point is typically strong enough to jack without bending.
(Assuming you don’t have 2 yards of mulch in the bed.) šŸ˜‰
