- Jun 3, 2022
- pompano berach fl
- dodge caravan
- Engine
- 2.5L Hybrid
I have hybrid. Do you? Maybe you said you did already. If so that would explain maybe why you don't have the horizontal bar I am describing.I jacked mine up at the rear of the front suspension cradle. I made a thread on it with a bunch of pics. Here:
https://www.mavericktruckclub.com/f...nch-weld-protectors-jack-point-musings.42422/
My pictures show a horizontal metal structure that goes across the truck and find its
end points below the bolt that attaches to the control arm that your jack puck appears to
be under.
I can't tell but does your truck have the same horizontal metal structure ? If so is your jack puck under that metal beam/structure that is just below the big bolt attached to the control arm? I didn't know the metal structure described would be bent by jack it up.
I guess alternative would be to jack not at the bolt location on the control arm but maybe 3 inches away from where your jack. It just dont know if that area would be flat enough.
I'm all ears. I hope I described it well enough
