- Nov 5, 2021
- British Columbia, Canada
- 2022 XLT Maverick Hybrid
- Engine
- 2.5L Hybrid
I know there was a post a year or so ago from a security researcher here about fully disabling the system on the Maverick. He said pulling the fuse was not enough to fully disable the telematics unit. He went as far as opening up the dash and removing the unit itself because it was still sending signals sometimes. The unit is behind the HVAC controls (22-24). We‘ll have to dig up the post, I think it was called something along the lines of ‘How to remove telematics unit’,Freedom is a fuse away.
Mike, @GenMaster
I don't know if this will help you or not.
Fuse 11/12 is actually one combined socket here are some pictures.
I hope this helps good luck,
GB
This is fuse 11/12's location on the fuse panel.
This is what it looks like once removed
Important You do not have to remove the glove compartment in order to access the fuse box
This is the passenger compartment panel you have to remove to access the fuse box
Good luck
