Flimsy hood mounting points?
Blue316
Reggie
NW Washington
I recently installed one of the hood strut setups.
Now I’m noticing that the hood on the Maverick is in no way reinforced at the hood hinge mount, so there is a lot of flex when you open the hood.
My concern is that we will start developing cracks or bending at those mounting points.
Has anyone at this point had any cracking or bending?
The only way I can think of to help distribute the load of the hood hanging out there is to make and bond to the hood some reinforcement plates.
The best thing would be if one of the oh so many companies selling these products would produce and sell such a thing.
It's a little bit of a pain to use and in the way sometimes, but I'll keep my prop rod. The hood is aluminum.
So far I'm still able to lift my hood.
It is a whole lot lighter than the steel hood on my wife's Escape.
Ford Maverick Flimsy hood mounting points? IMG20241008130450
I guess I'll keep using my hood prop rod. If and when my tailgate strut gives out, at least I won't be hit on the head and it's less than $30 to replace for the convenience of just letting the tailgate drop.
Ford Maverick Flimsy hood mounting points? Screenshot_20250128-100731_YouTu
If it is good enough for a Cadillac it's good enough for my Maverick.
dusty1787
Dustin
Wisconsin
2023 Maverick EB Lariat
If you search the forums there are actually a few people who have had issues with the hood struts. Something about them causing too much pressure when trying to open them and possibly causing the cable to dislodge from the handle and thus causing you not to be able to open the hood.
If I remember right that is. Either way, I am perfectly fine lifting up the hood the old school way. To each their own tho.
Tbone289
With as light as the hood is, why risk it by adding the strut(s)?
HRG
Agreed, and I feel the same way about the tailgate. Gas-charged struts all have to be replaced eventually too, so they ensure future maintenance cost.
Carlitos_92
The whole truck the hood is attached to is "flimsy" to some degree. :wink:
Hot Runr Guy
West Chicago, IL
Hahahaha! Heck, the way the hood shakes in certain high-wind situations (like an oncoming semi on a 2-lane road) I'm almost considering going old school and adding hood pins,,,
For you youngsters;
HRG
Ford Maverick Flimsy hood mounting points? Screenshot 2025-03-24 153142
VBMav
Indiana
www.theveteranscheck.com
2022 Maverick XLT; 2025 Escape PHEV
Maybe. But that REALLY makes a difference in lowing the tailgate. It's was too easy for it to get away from me before I installed the strut. My wife wouldn't even try to lower it after the first time - but then, we are really old. :facepalm:
Blue316
Blue316
Reggie
NW Washington
Struts VS prop rod…
I like the idea of the struts. Why? I just do.
But that said it never occurred to me that the hood is so light weight that the struts might just destroy the hood.
So I will be going back to the prop rod.
I can’t imagine that a set of bonded reinforcement plates would be cheap.
MYNOMAV
Keith
Oshkosh WI
2024 Maverick XL hybrid
Hood struts were the first mod to my 07 mustang. I did have to replace them after fifteen years. My friend had his hood open at a car show and wind lifted the hood, the prop rod fell over the fender with the hood slamming down on it. Yep, crunched fender. I use the struts because they keep the hood up about 2 inches higher. For us tall guys that's a plus. I put the Redline tuning struts on the Maverick. Works great!
Blue316
Blue316
Reggie
NW Washington
Have you checked out how much flex in the hood there is at the hinges? It’s lifts the back edge of the hood off of the mating surface
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
That’s exactly why I sold my struts. I hate the hood prop but don’t want to bend my hood trying to close it against the pressure of the struts. Had a beautiful CF hood on a car once and the oem strut pushed right through the mounting point after about a year of use.
