Enabling additional drive modes on 2025 XLT AWD Hybrid
JJTech
Pennsylvania
2025 Maverick XLT, 2006 GMC Canyon
Has anyone messed about with additional drive modes on the 2025 MY?
Wondering if it would be possible to get some of the more interesting modes on the AWD hybrid.
I tried enabling basically all of the numbered modes in EZ mode using Forscan, but only #9 did anything (Lobo mode).
I haven't yet tried driving in Lobo mode, tbh I'm kinda interested to see what would happen lol.
Unsure if there is some additional check for the FX4 package or hybrid that I need to bypass? Will they simply not function on a hybrid no matter what? Is this a MY2025 thing?
LPAHL
Alberta Canada
2025 Maverick XL shadow black
I just saw on another post that there's a drop down menu where you can choose Vehicle series
Base
Or
Offroad
Wonder if there's anything there to do in conjunction with the numbered Sdm
I want the offroad on an XL btw
Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
Jute how, did you ever drive it in Lobo mode? Learn anything further?
JJTech
JJTech
Pennsylvania
By combining the advice on this thread: https://www.mavericktruckclub.com/f...o-sport-mud-and-snow-confirmed-working.10229/
(specifically the modification to 760-04-01 which seems to override the normal checks that prevent using Off-Road and Lobo modes on the hybrid)
with the discovery that Off-Road is now SDM Mode 22: https://www.mavericktruckclub.com/f...-on-2025-maverick-tremor-using-forscan.67391/
I was successfully able to enable and drive in Off-Road and Lobo mode on my '25 Hybrid AWD.
Ford Maverick Enabling additional drive modes on 2025 XLT AWD Hybrid IMG_1458
Ford Maverick Enabling additional drive modes on 2025 XLT AWD Hybrid IMG_1461
Not sure how to properly test their effects, but they both seem to be doing something like their original intention. Lobo seems like Sport mode just with less fake shifts, and perhaps a more aggressive throttle curve (and TC disabled). Off-road shows that info display, disables TC, and makes the throttle curve very lazy.
Zaluss
Renton, WA
2025 Ford Maverick Lariat Eruption Green, 1988 Toyota Celica Alltrac
Pretty interesting. Does the AWD screen work? Meaning does it display which wheels are getting power, etc for the hybrid AWD?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Well there is the fuckin AWD screen finally!!!!
Great work OP. Will finally be busting out my Forscan this long extended weekend!!!
JJTech
JJTech
Pennsylvania
Well, I don't have an FX4 Maverick to compare against, and I haven't yet tried the hybrid actually off-road, but I'm a bit suspicious? I didn't see anything on a quick drive around the block...
Are there supposed to be numbers next to the wheels? Or color change or something?
Zaluss
Renton, WA
I tried searching for a video example but I couldn't find one. Maybe one of the FX4 or Tremor guys can chime in.
I noticed though that the off-road mode for the Tremor enables the front camera with a trail preview. Since the Lariat also has a 360 camera, did this activate for you? If not it could be another setting to enable somewhere.
JJTech
JJTech
Pennsylvania
(I have an XLT, not a Lariat, so no front camera is physically present. I did see a setting labeled "Trail Camera" or similar in FORScan)
Zaluss
Renton, WA
Oops sorry thought you did for some reason! I may look at enabling it this weekend on my Lariat as the trail camera would be handy.
710-oil-614
Cal
If you give it a hard throttle input (50-60% or greater) it will engage AWD and you will see white bars fill all 4 wheels.
Jpalmer1
Dallas, TX
JJTech, so, does it add the AWD screen to be available any time, or only when in off-road mode?
Mabcim
Rochester, NY
I was just trying Lobo mode. While doing that, I tried the 'Off Road' screen I did on my '22 and that worked. It added it to the My View list of screens, so you can see it anytime. I didn't actually drive with it to see, as I ended up reverting the module when Lobo mode was throwing DTCs for me.
IPC 720-07-02
x7xx-xx
I had a 5 and changed it to 7.
That field is 4 settings/bits, so the 5 was 0101. Making it a 7 becomes 0111. So it is the 2nd bit, from the right, that needs to be toggled. So be sure to leave the others alone. For example, if you had 1 (0001), then make it a 3 (0011); if you have 4 (0100), then make it a 6 (0110).
I ran my '22 with that change for 2.5 years with no problems.
Jpalmer1
Dallas, TX
IPC 720-07-02
x7xx-xx
Mark, have you enabled the off-road screen on you 2025 yet?
Mabcim
Rochester, NY
I just tired the IPC 720-07-02 x7xx-xx; which worked and added it to My View. Which is what I would call the AWD screen. I did not try the Off Road drive mode.
