Enabling additional drive modes on 2025 XLT AWD Hybrid
Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
I just tried IPC 720-07-02 x7xx-xx on my 2025 Lariat Hybrid AWD and it did NOT work. My original was IPC 720-07-02 0500 083D . . when I change the 5 to a 7, it automatically changes the D to and F, resulting in IPC 720-07-02 0700 083F. I tried to change the D back to an F, but it persists and won't accept the D . . ? When leaving the F and testing, I can't determine anything happened or changed . . My View and everything else seems same as before . . ?
Mabcim
Rochester, NY
The last 2 digits are a checksum. They are calculated based on the other values. When you change the other values, those last 2 will always change, so what happened is expected.
The IPC change makes it so the Off Road screen is available to be added to My View. So you have to 'check' it for it to show.
Jpalmer1
Dallas, TX
Oh Yeah! . . Add it ! Duhhh! Thank You!
Cvinnedge
Chuck
Virginia
2025 Ford Maverick XLT AWD Hybird
Hello forscan guru's. I am new to forscan so have only been using the EZ Mode. I wanted to enable all the drive modes and this what has happened so I am hoping for some advice.
I have the 2025 AWD HYBRID XLT. When I enabled Sand Mode it gave me Lobo mode. Ruts does nothing. Rock crawl doesn't work. Mode 22 enable OFF Road and I think turned on the off Road screen on the dash.
The problem is now I only see the Off road display. I no longer see the My View options I have selected. When I try to access my view it opens the office road screen only and won't cycle through the other screens.
Any advice would be greatly appreciated.
Chuck
charlesb
Charles
canada quebec
Maverick xl hybrid 2025
will be watching this as i want to try the off road on my 2025 xl Hybrid awd :)
rockon
Wisconsin
Chuck
I had a smialr thing
Chuck
I had a similar result. It only happens when I go into Off Road mode and then come out and go into a different mode. In the new mode I only see the Off Road screen. From there I can go back and select MyView to get everything back.
rockon
Wisconsin
Played with adding Off Road mode to my 2025 XLT Ecoboost. It all came up including the Off Road screen. Did some hill climbing. All the angles displayed correctly but I didn’t see anything change on the wheels at all except front wheel steering direction. Tried going up a 20 degree incline in my yard. Stock Wheels started to spin, truck started rolling backward, hit the brakes but truck stalled out and engine light came on. It had an ABS fault. Went back into forescan cleared fault and put it all back to normal. I am not an off road expert so could be my driving skills.
cristianarg1
Cristian
perlita1!.
Maverick XLT 2025
[CITA="JJTech, mensaje: 1118064, miembro: 40470"]
Combinando los consejos de este hilo: https://www.mavericktruckclub.com/f...o-sport-mud-and-snow-confirmed-working.10229/
(específicamente la modificación a 760-04-01 que parece anular las comprobaciones normales que impiden el uso de los modos Off-Road y Lobo en el híbrido)
con el descubrimiento de que Off-Road ahora es el Modo SDM 22: https://www.mavericktruckclub.com/f...-on-2025-maverick-tremor-using-forscan.67391/
Logré activar y conducir con éxito en los modos Off-Road y Lobo en mi vehículo híbrido AWD del '25.
No estoy seguro de cómo probar correctamente sus efectos, pero ambos parecen cumplir su función original. El modo Lobo se asemeja al modo Sport, pero con menos cambios de marcha simulados y quizás una respuesta del acelerador más agresiva (y el control de tracción desactivado). El modo Off-road muestra la información en pantalla, desactiva el control de tracción y suaviza considerablemente la respuesta del acelerador.
[/CITA]
¡Hola! Soy nuevo en el grupo, ¡y agradezco toda la información que compartís aquí!
Pude activar los modos todoterreno y Wolf en mi Maverick XLT 2025. Tengo una pregunta: entiendo que el Maverick Lobo tiene 7 velocidades y el XLT tiene 8. ¿Habrá algún problema al usar el modo Wolf en el XLT? Ya probé mi Maverick XLT en modo Wolf y alcanza las 6000/7000 RPM antes de cambiar de marcha. ¡Me da miedo romper algo! Jaja
Pierre777
Pierre
NY Long Island
Maverick XLT, Dodge Caravan and Hyundai Elantra
Any driving difference in "Lobo" mode? I have the off road mode turned on and don't seem to see a difference Of course I get the angle displays and the degree the front wheels are turned but I don't see if the rear wheels or front wheels are moving.
Maybe I need to be off road where tires slip?
Wondering if "Lobo" mode skips a gear or not. I have a 2025 awd 4k to Lariat
Pierre777
Pierre
NY Long Island
Bump Bump - Guess No further info on this?
MaverickDragon
Grand Canyon, AZ
I'm looking for the flying submarine mode, but it doesn't seem to be an option...
Pierre777
Pierre
NY Long Island
There aren't any "gears" in the conventional sense in a hybrid's e-CVT, so it won't skip anything
LOL - Totally forgot about that I have a E-CVT . I guess all this so hacking has made me think that I am some how getting additional performance that Ford kept from me. LOL when in reality I got everything I paid for. thought I do like having these screens.
Pierre777
Pierre
NY Long Island
Yeah, I guess we all want to feel like we are getting some sort of option that is being held from us when we are getting exactly what we paid for. Though the flying sub mode would also be nice. lol
