Does the A/C in the 2024 Mav Lariat actually get cold?
umpkey
Bunnell, FL
Yes my 24 Lariat Hybrid A/C gets very cold and helps with these recent hot days in Florida.
KO Stradivarius
The Disputed Lands
'25 XLT
A/C in my `24 Lariat Hybrid does here in Arizona...
I'm your neighbor from Gilbert, AZ. It's all about "Delta T", the difference between the air temp inside the cabin and the air temp the system is able to put out from the registers. Delta T for a good system is 15-20°. But humidity also matters. More humid=more difficult to cool.
I have a small thermometer like this: Amazon LINK. You can buy them at AutoZone, too, etc. Which takes the guesswork out. It will slip right into the register. I keep mine in place there always.
Ford Maverick Does the A/C in the 2024 Mav Lariat actually get cold? 61MD5Ti1ocL._AC_SX679_
My 2 month old '25 Hybrid in Arizona will output ~50°F cold air (after a while) set on "LO" when it is >100°F outside after work at 4pm. That is cold, but not ice cold because the cabin air is probably around the high 70's after like 5-10 min. It takes a while to output 50° air because it is about 130° inside when I first open the door. And it won't ever get down to 60° inside because it's hotter than Hades outside. I'd guess on the afternoon drive home it never gets below 70° inside even at the lowest temp setting with Recirc on.
When I start driving to work at 6:30am in the morning and it's about 75° these days it will output 40°F cold air, which is frigid so I turn the temp setting up to about 68-70. Then it will output around 50°. You just cannot expect the AC to always output 40° no matter how hot it is outside.
So if you are really concerned, get a thermometer like this and if you are getting 40°-50° air output from your ducts, you are good.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
If yours doesn't you need to have it checked. my MY22 will freeze you out, best A/C in a vehicle i think i've ever had.
I agree, best HVAC (in the front seats) and someone in the back mentioned it was cool.
Kidney Man
Tony
Findlay, Ohio
Ford Maverick…Mazda Miata
Still very little A/C today. 80 outside Mav hot on inside after 10 miles. Calling local dealer on Monday!
FischAutoTechGarten
Peter
The automatic temp control of the Lariat seems to be sentient, with a mind of its own, exercising its own free will on occasion. Not sure what are all of the variables it considers in it's control scheme, but it seems to allow things to get too warm or too cold at times, not constantly, but at times it's taking poor control decisions. The system on my 2002 VW Passat GLX 4Motion Wagon was more repeatable in terms of it's behavior than my 2024 Ford Maverick Lariat AWD EcoBoost.
Here's my AC thermometer back from the days of R12 recommended temperature range was the Shaded area below 50° coming out of the vent. I bought this thermometer
at an auto parts store in the 70's
Ford Maverick Does the A/C in the 2024 Mav Lariat actually get cold? 20250607_171509
AC vent thermometer from the R-12 age
Oscarcat
Eric
Encinitas California
Me: 24 hybrid Lariat and yes, the AC gets really cold. Be sure to select the button to have the air come out the dash vents as opposed to the floor. It is also dual so see that both sides are set to a low temp setting.
When I first got my 2022 XLT, the A/C didn’t feel as cold as it should. Even with the fan on full blast, the air just wasn’t that cool. This was a brand-new truck, so I was surprised. I decided to check the cabin air filter and found that it was ripped and being sucked into the blower motor. After replacing it, the A/C performance drastically improved — it was ice cold. I would definitely check the cabin air filter!
I found deer feeder corn on top of my cabin filter.
I have a meat thermometer that looks like yours😳
ekusafetyman
Larry
Richmond, KY
2025 Maverick Lariat
I agree with Kenv24. This is the coldest auto A/c I have ever had.
You certainly wouldn't want to inhale that!
Damn energetic pack rat. Nearest deer feeder about 2000 feet away! Sprayed replacement filter with peppermint oil.🤞
