Does flat towing add miles to the odometer?
ckjergaard
chuck
Lakeland, FL
23 Ford Maverick Lariat Hybrid FWD
I just bought a 2023 Maverick Hybrid. I am researching base-plates, tow bars and braking systems.
ckjergaard
chuck
Lakeland, FL
Short answer after flat towing my 2025 Maverick Lariat AWD Hybrid almost 7,000 miles. No the odometer does not register miles during flat towing
Thank you.
Thank you.
Thank you.
John R C
Broomfield, CO
2011 Subaru Outback; 2021 FR 30DS RV; 2025 Maverick Laramie Azure Grey
If your Maverick is a '23, it is NOT flat towable. There was a transmission change beginning in '25 that allows flat towing. Check your owners manual before spending any money to prep for flat towing. I'll be hooking up my '25 behind the RV to head out in two weeks or so.
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
Hybrid IS flat towable. I flat tow my 23 often.
John R C
Broomfield, CO
Cool! I know there was a tranny change to -28 for '25. I'da got one earlier knowing this.
Bert Rooster
Albert
Rio Rancho, NM
97 Toyota T-100, 06 Jeep Liberty, 2018 Tiffin MH
Short answer is no. I've towed my 2023 XLT Hybrid almost 25 K miles and the odometer just turned over to 8 K miles.
Check out etrailer.com for base plates, tow bars and lighting kits. I would look closely at the Demco base plate, it is the least invasive install and can be used with multiple tow bars. I installed a Roadmaster base plate which required removal of the lower Active Shutter assembly, the Demco does not. The Demco was not yet available when I installed my base plate.
Ford Maverick Does flat towing add miles to the odometer? Maverick hooked up 01
Cancunbadlands
Cancun
Cancun
No
bsenecal
vermont
, 2022 Ford Bronco, 1968 Ford Mustang, 2022 American Coach American Dream 39RK
Reading the comments on etrailer, some have had to move their Adaptive Cruise Control sensor.
Not interested in having to do that then bring to dealer for a recalibration.
Hopefully I can find a baseplate that fits with little to no additional modifications.
Seems like the companies that make them to fit multiple models versus one designed specifically for the Maverick Hybrid.
