Does 12v outlet only work when engine is on?
Gunny Buck
Lonnie
Clarkston,Mi
2022 Maverick Lariat AWD Fx4 Luxury
With the 120vac outlets, do you need the truck running to use? If not, how long can you use it without starting the truck?
DarkStormy
William
Maine
Nissan Frontier
Good question, I think it may depend on if you have the ecoboost or hybrid.
MaverickPR
Ricardo
Puerto Rico
Maverick XLT 2022
You need to run the engine to be able to use the 12v and UCB ports inside the cabin.
RabidAntiDentite
Dan
Fort Worth, TX
2022 Maverick XLT FX4
The outlets in the bed seem to work about 30 to 45 mins after turning off the truck. I installed an led light kit in the bed and it works.
Not sure if this helps.
Gunny Buck
Gunny Buck
Lonnie
Clarkston,Mi
Thanks
Kenny
Kenny
2022 Maverick XLT 2.0 Ecoboost with AWD, Tow Pkg
This number is adjustable in Forscan. There is a limit though, you can't leave it on all the time.
colinl
Colin
ICT
I might have to look at that, because my two 120V 400w outlets turn off immediately after I turn off the ignition. They also don't turn on immediately, it takes a 30-90 seconds after I start the engine.
Might be 12V battery charge level, though. My truck came with EF and I was getting deep sleep notifications, but it's been quiet the past 6 months since I reset the Battery Monitoring System.
