Do Snow Tires Help
lm126027
Larry
Central MA
2024 EB
A question for AWD owners who have driven their Mav in the snow with & with out snow tires... Do they help??
The reason for my question is that I have a set of 225/65R17 Blizzaks currently mounted to rims for a 2016 Jeep Cherokee.(already checked, the rims won't fit the Mav) If snow treads do help I was considering buying a set of rims for my Mav and having the treads remounted. SWPA doesn't get as much snow as Buffalo NY but we do get snow.
One more question... Will 17s fit a 2025 AWD hybrid lariat 4k?? My research seems to say yes but I'm not 100% sure.
My 24 Mav Lariat, AWD, with tow came with 18", my snow rims are 17. When I bought the snow's for the 17 rims the tire dealer said that if my speedometer read 65, I would actually be going 64.75. Thought close enough... However, using WAZE, at 75 on the speedometer, WAZE says 72/73... That's enough that the mpg numbers on the dash or calculated arn't accurate. Also, miles to empty numbers are worthless... at 10 - 25 MTE my gas gauge shows about a quarter of a tank. Going to talk to dealer to see if that is something they can adjust when I put the snows back on.
Ryom
PA
2025 Lariat 4K BAP Eruption Green
You just need a 17" tire with an aspect that matches the 18" diameter. You'll have a bigger sidewall on the 17" which may help ride comfort and pothole damage resistance.
You can search for tire diameter calculators to find your numbers.
TJ2023
Detroit
24 Ford Tremor
Will they help? Sure. Are they needed, probably not. I have lived in northern MI most of my life and never bothered with snow tires and have never had issues. Snow tires would be needed if you had a sports car that you wanted to drive year round or if your vehicle came with summer tires that aren't good for low temps. Mavericks come with all season tires which should be good for anyone not living in Alaska. It is more about how you drive in snowing conditions that really maters. Snow tires aren't a bad idea though as they will help make your normal tires last longer. If it gives you peace of mind go for it. As far as the 225/65R17s, you should have no problem with those with no mods.
lm126027
Larry
Central MA
2024 EB
That is what the tire dealer was suppose to have done. 65 vs his quoted 64.75 was as close as they said they could get, but that is not what I am seeing vs WAZE.
phoneguyinpgh
phoneguyinpgh
Pittsburgh
2025 Lariat Hybrid 4K
Here in SWPA we have some serious hills. Not that high but steep.
KrS
KrS
St Marys ON
2024 Maverick XLT Tremor - Azure Grey Tri
My Wildpeaks are tri-peak. They were awesome last year, driving by people stuck on back roads (after asking if they needed help of course).
I had FWD with winter dedicated tires.
I'd rather have AWD with all season over that again. --> spin spin spin.
Scott Asheville
Scott
Asheville, NC
Back in the day 50 years ago, snow tires on RWD V8 Detroit vehicles was the difference between staying on the road and sliding off. Nothing has changed. I have an AWD with all season Defender 2 here in WNC, where we see snow a few days a year. It's fine going up and down my ridiculously steep and slippery paved mountain driveway (I do need to put it in slippery mode).
But if I was back in the snow belt, it would be winters come 1 Nov.
lm126027
Larry
Central MA
2024 EB
Snowtires are a must when your a snowmobiler and up in northern Maine and eastern Canada much of the winter. I backed right out of this mess, though did shovel about 3 feet behind each tire to make sure I could get started. lol
Ford Maverick Do Snow Tires Help 20250217_071755
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
Wait. There is still a Fiat 128 on the road? I figured they all caught fire and burned up by now.
That thing was indestructible. My 1970's HS driving style failed to stop it, even when I drove it straight through the woods like an ATV. It leaked oil, and the engine would shut off when there wasn't enough in it. I'd get out, put in a quart, and drive off. Try THAT with anything but a Camry!
TJ2023
Detroit
24 Ford Tremor
On RWD trucks it is way more important to have weight in the bed of the truck than to have snow tires. Mavericks are all either FWD or AWD so there is no need for it. Slippery mode isn't really needed either, it only limits how fast you can hit the throttle so you don't spin the tires so bad. If you are used to driving in the snow then it doesn't add much benefit.
Surly Old Bill
bill
Richmond, CA
2024 Maverick XL
when I lived in Summit County and Park County CO, a lot of local workers had 2wd pickups, and would throw in a 1/4" thick steel 4x8 sheet in the bed in the winter. And use studs (90's). Bonus: we'd charge Texans $20 to pull their Suburban or other giant 4x4 SUV out of the ditch. I'd do that with my Toyota 4x4.
Kind of eager to see how the Mav does in snow; maybe next week when I go to Central Oregon.
Escapologist
Niagara Region, ON
I get what you're saying, if you're gonna habitually outdrive the capabilities of your tires and brakes, it doesn't matter how much grip or brake you've got.
However, I am finding more I need extra margin to steer around the idiots coming at me sideways these days, even though todays real All Seasons are probably better than snow tires of 20 years ago due to better rubber compounds and computer assisted tread design.
My beef with winter tires is they are typically good at ice/snow/slushy-wet, pick any two out of three, and since our roads around here get plowed and salted, and I'd pick my all seasons to have good puddle clearance and low aquaplaning, they'd tend to be good on the slushy-wet we'd have 80% of the time, and go careful on the rest. Though picking them with decent siping and some chonky blocks would give them a bit of a chance in the other realms too.
However, as I say I'm finding myself rarely alone on the road and I wanna avoid the assclowns, so I am seeking winter tires.
Having some thoughts about getting the new Tiger Paw Ice&Snow 4, since one of it's strengths that has come out in the small number of reviews so far is good slush pumping, and that's something I rarely hear, and like I say it's 80% of my winter. Also meant to be LRR.
I am possibly going to have to spend the majority of the tire fund on wifey's Escape though and have to get some used "get by for this winter" stuff for the Mav this year. Looking at a set of Hercules Avalance RT (by Cooper) which are going quite cheap, wifey might get the Tiger Paws, dunno, still trying to evaluate options, had a train of cash draining events and don't wanna dump $2k per vehicle down this drain atm.
Phimosis
Larry
Santa Clarita, CA
Absolutely 110%. Heck, I'd take a FWD Civic with winter tires over a 4x4 pickup truck on all-seasons. Winter tires stay soft and pliable in subfreezing temperatures and also have micro serrations in the tread blocks, which allow the tire to grip on ice.
Yes. You could get steelies from an XL, or 17" XLT or Bronco Sport wheels, or maybe these ones from Costco.
https://www.mavericktruckclub.com/forum/threads/25-xl-in-costco-rims-17-x-8-impulse.65684/
You’ve hit the nail on the head here. These are more aptly called winter tires or ice tires, rather than snow tires.
Ever watch snow wheeling videos or videos of Arctic trucks in open snow fields? Are they using Blizzacks? Nope, they’re using massive mud terrain tires for flotation and large open tread blocks to prevent clogging of the tread pattern.
Blizzacks have silica -sand- in the tread pattern to increase friction on ice and thousands of tiny sipes to increase the wicking away of melted water to prevent the ice skate effect, where the skate is sliding on a thin film of water. Blizzacks are all about ice traction.
