Do dual piston calipers made a difference?
kd2dhp
New Jersey
2025 Ford Maverick XLT
I have a 2025 XLT AWD Ecoboost without the 4k tow package and I have single piston front brake calipers. In my opinion, the brakes suck. My 90's Buick with rear drums stops faster and straighter. Would moving up to the dual piston calipers used with the higher trim levels help the situation noticeably? Has anyone here driven both or upgraded their truck?
Maverick123
25 hybrid
I don't know how the piston area compares in the single vs dual piston calipers but often the dual pistons add up to a bigger area.
Increasing the piston area in the calipers without also upgrading to a bigger master cylinder decreases the hydraulic leverage ratio. So, everything else being equal, it'll take more pedal stroke to get the same clamping force.
I'd try flushing the calipers as a first step and possibly upgrading to better pads. I'm a big fan of Akebono pads, if they're available
Bdesign
Santa cruz, CA
2025 Lobo MPC EB
dual piston calipers only on Lobo- from Focus ST
kd2dhp
New Jersey
According to my parts catalog, the truck uses the same master cylinder/booster regardless of the type of front caliper.
I'll definitely give Akebono pads a try. I'm a firm believer in them, but I haven't needed to replace my brakes yet. Also plan on flushing the system with Super DOT4
Chops
Lobo
Had a loaner 26 Bronco Sport Outer Banks with puny brakes while my Lobo was in the shop last week. The BS stopped quicker. Caught me by surprise the first time I braked…
Thought I “bedded” in my brakes properly when new - now I’m not so sure!
edit…pics
Ford Maverick Do dual piston calipers made a difference? IMG_0602
Ford Maverick Do dual piston calipers made a difference? IMG_0603
Tbone289
Are you not able to lock up (or induce anti-lock) with your single-piston calipers? If you can't induce anti-lock with your single-piston calipers, something is wrong. If you can, dual-piston calipers aren't going to shorten your stopping distance. Larger brakes and dual-piston calipers are for better brake heat management and finer control over braking, not for reducing stopping distances.
If your goal is to reduce your stopping distance, you'd be better off buying a tire with better grip.
Tailender
Will
Poconos
I can't comment on what parts would be better, but on my truck, the difference between slippery mode and regular mode is increíble. Maybe the mode has some play in the results you're feeling?
Manning
Northwest Arkansas
2025 Lobo low
Yep, unless something is mechanically wrong, tires will be the #1 thing to reduce stopping distance. The OEM goodyears on my lobo would trip the ABS very easily. I now have Michelin PS4's. MUCH better.
Marty
2026 Ford Maverick Tremor
My 1978 Honda CB750 had single pistons.
I had perfect brake control with three fingers mid lever.
My 1980 CB750F had dual. Perfect brake control took two fingers at most under hard stop conditions, mid lever.
And less brake fade.
You could upgrade single pistons with stainless steel non expanding brake lines and get the same gain.
On a sport bike precise brake control is everything.
And if you upgrade dual piston system with stainless steel lines, well yes you’ll kick it up a notch.
Last step,
Drill the disks And pick sticky tires. :’P
MikeS1942
Windsor Ontario
24 Maverick Lariat
It's the tires that stop the vehicle.
grandpopa'sMPGs
Cincinnati, Ohio
Ford Maverick, Chevy Cruze
single piston are better than duel piston. In dual piston if 1 piston gets a little stiffer then the break pads will be unbalanced. single piston will apply pressure that is balanced even if it is a little stiffer. The metal plate behind the pad should be stiff enough to prevent bending.
Bdesign
Santa cruz, CA
2025 Lobo MPC EB
dual piston calipers are usually larger (more surface area), less prone to fade and apply more force. Single piston calipers are cheaper.
YV1227
Michele
2025 Maverick Lariat, 2007 Prius Base x 2
From my bike days I remember changing the rubber lines for SS reinforced one, it made the brakes 70% better just doing that, does Brembo make a kit for the Mav? that should take care of the rest.
MYMAVXL
Chuck
Connecticut
I’m actually very happy w the Mav brakes. I do lots of highway driving and have had a number of close calls where I mashed the brakes quickly and hard! My Mav just hunkered down, stayed straight, and stopped without kicking in ABS. If your ABS seems to kick in too quickly or things get squirrelly then maybe something needs addressing. Sometimes it’s just a “feel” thing too. I’ve found that you can’t be shy w these brakes when you need to STOP NOW!
I also remember swapping rubber hoses for braided steel on my motorcycles and that had a big impact on feel and fade…worth a shot and probably not too $$.
