Clark6
Ray
Georgia
1987 Buick GrandNational 1996 Chevy Silverado
I have about 8 of these under my boat shelter for my Buick .. The thought did run across my mind glad someone carried it through Excellent Job!!(y)
nunucello
Marcello
New York
I hope this is helpful for people looking to DIY a bed mat. I purchased the horse stall mat from Tractor Supply ($47.00). Uncut, the mat is 4' x 6' x 3/4" and weighs a hefty 94lbs. I thought about using power tools to cut it, but after doing some brief Youtube research, I decided to cut it with a utility knife. It takes multiple passes with a new blade to cut through the material, but it wasn't too much work.
The main thing you need to do is cut the mat to the length of the bed, cut out the sections for the wheel wells, and then cut out to pieces for the tie downs near the front of the bed. To get a clean cut for the tie downs section, I used a forstner bit on the corners.
I also used a belt sander to break the sharp edges and round the back corners.
That's basically it. It took about a couple of hours of work to plan and make all the cuts. Here it is in the truck:
Outstanding work !!!!!!!
Blues
Steven
Pa
Great job and price! I did get the Ford bed mat but it didn't have the holes for the bed hooks.I will use your idea for cutting out for the holes.Thanks for posting!
bighap
Oregon
2023 Maverick Lariat Hybrid
Perhaps! Someone on reddit suggested using epoxy or some other means to glue them together. I'm going to do some experimentation with the scrap to see if its worth it.
You probably don't even need to do that. Just make it as snug as possible and it won't move.
Ztnichol
Zach
Reading
Subaru Outback
Looks awesome!!
timcal
mass,usa
xl maverick
Did you have to anchor to bed or did weight hold it in place.
I drive 80% highway
ebxltfwd
ebxltfwd
B
Georgia
Ecoboost XLT Carbonized Gray
I drive 80% highway
it’s so hefty it’s not going anywhere. I even had a scrap piece 3” x 30” sitting in the bed and it didn’t move around while driving on the highway.
TB84
US
Mavxl
Looks great. I'm a mid aged retired veteran and would sincerely appreciate it if you could share the measurements for the cuts. Start/end for wheel well angle, tie downs, etc.. I'm sure it took some thinking and would certainly be helpful. Thanks
Lone Star Proud
William
Central Texas
Ford Maverick XLT
I did that with my old Ford Ranger but I used a big piece of cardboard for the template and cut it with a jig saw.
The jig saw sounds like a great idea
Blues
Steven
Pa
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
You do good work!
My second purchase for my Maverick was a 3'x4' mat from Tractor Supply, which weighs only 36 lbs and I didn't have to do any cutting.
I showed it to my wife, who said, "You paid Line-X to spray your truck bed and then you put a rubber mat on top?"
She just doesn't understand.
Ford Maverick DIY Bed Mat made from a Horse Stall Mat t1
