Diode Dynamics Fog Lights Installed - Experience & Photos
rd4440
Michael
San Antonio Tx.
2022 lincoln aviator, 2023 Ford maverick
Received diode dynamics fog lights installed with the help of my (2) brothers took us about 6 hours to install. I put in yellow(amber) flush mounted fog lights from amazon about a year ago posted pictures of them installed. With the flush mount lights did get flashed from oncoming traffic so did not use them hardly at all. These dd fog lights are awesome for night time driving I would recommend everyone with a 22-24 non tow hook Maverick to get these lights. Drove home about 2 hours after install back roads in Texas have to watch out for deers & wild hogs crossing road did see 3 wild hogs in the ditch a good distance before i came up on them the lights have excellent visibilty for the ditches on each side of the road. During drive ran fog lights with low beams the entire drive never needed to turn high beams on adjusted lights before i left never did get a flash from oncoming drivers so that let me know that i have the lights adjusted correctly. Also the hole i drilled for the light adjustment i put in push pin retainers pic below. I did not use the wiring harness from diode dynamics since i already had the flush mount fog lights hooked up to a 4-pin relay and fog light switch already in use. The backlight activation wire did not hook to side marker light 12 pin molex ran wire from fuse #3 through firewall under hood connected to blue backlight wire they are always on with the ignition running. Also while the front bumper was off added front camera underneath front license plate frame pictures added.
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Fog Light Install (1)
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Fog Light Install (2)
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Fog Light Install Front Bumper Off
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos DT Wire Hookup
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Driver Side Tire Removed For Fog Light Install
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Passenger Side Tire Removed For Fog Light Install
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Fog Light Switch Off
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Fog Light Switch On
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Driver Side DD Fog Light Adjustment Hole Push Pin Retainer
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Passenger Side DD Fog Light Adjustment Hole Push Pin Retainer
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Daytime In Garage BackLight Feature On DD Fog LightS
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Daytime In Garage DD Fog Lights On
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night time Outside View DD Backlight with Low Beams
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night Time Outside View DD Fog Lights With Low Beam
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night Time Driver View DD Fog Lights With Low Beam
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night Time Fog Light Switch Powered Off
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night Time Fog Light Switch Powered On
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Daytime Flush Mount Lights
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Night Time Flush Mount Lights With Low Beams (1)
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Lower Bumper Cutout to Install Fog Lights
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Outside Front Camera View (1)
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Front Camera View Inside Cabin Monitor
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos Wiring Harness Install DD Fog Lights
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos My DD Fog Light Truck Wiring Diagram
Ford Maverick Diode Dynamics Fog Lights Installed - Experience & Photos DT 4-Pin Fog Light Connector
Stewart
Henderson, NV
Lariat
Nice install
Mervin the Maverick
Ken
Sierra Vista, AZ
2019 Kia Niro, 2019 Hyunda1 Kona, 2002 Chevy S10
I need help understanding the Diode wiring. I get a light on the switch, but I cannot get the fog lamps to turn on.
Mervin the Maverick
Ken
Sierra Vista, AZ
