dial shifter went bad
jbrown9889
Justin
Clover, SC 29710
2024 Ford Mavericks XL
Find out almost 2 weeks ago. On my 2024. They tested it. I have problems getting stuck in Reverse. When I turn off the truck, than be try to start it. It will not start. Then move it to park than it will be fined every 2 months it do it. I tell my ford dealer to test it. Turn out when they turn back bad. And parts was on back order. Finally the parts come in. But I miss my truck, they have it for 2 days now. They say it will be ready tomorrow morning.
Ford Maverick dial shifter went bad IMG_0174
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
That sucks I hope they get it fixed for You.Let us know if when it's fixed.
Itsdavebr0
NY
2024 Maverick XL
Mine does the same thing. I assumed I was turning the truck off in Reverse.
KenR
KenR
DFW
F150
My 2025 Maverick Hybrid Lariat automatically shifts i to Park from any drive selected when the Keyless Start-Stop button is push to turn-off the truck. The auto shift into Park doesn't turn the shift knob, electronics does Park selection.
Frenchy
Bert
Taylorsville Utah
I have problems with mine too but different.
Even withe engine "started" it will not turn to get in gear, it is blocked in the park position.
Sometime I have to turn the engine and and off several times before I can rotate the knob.
I got my Maverick DEC 27 2025
sapperforward
Rich
2024 maverick lariat
Silly question but are you holding the brake pedal down when you are trying to shift it out of park . I was forgetting that when I was getting used to the rotary dial when I first got her and finally figured it out 🙂
Which is a good point - because it could be an actual issue with brake-shift interlock.
Others besides myself have reported starting to hear it under the center console eventually, when it was not heard before.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
They are working on right now. It be 5 o clock is ready for pick up. I going in the morning to pick it up.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Go to ford dealership had then checked your shifter to see if is bad.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Got the truck back today
Ford Maverick dial shifter went bad IMG_0178
theslinky1
brian
texas
tundra mavrick on order
Does you truck double honk when this happens? I have had this happen a couple times and the horn would honk twice when it happened.
jbrown9889
jbrown9889
Justin
Clover, SC 29710
Yes, had it double honk before.
