Dead battery after flat towing, 2024 Maverick Hybrid.
Mrk
2024 Ford Maverick Hybrid
After flat towing 5 hours behind RV there was no response when pushing the push button ignition switch (button). Dashboard totally dark. Applied 12 v. via jump start, Dashboard comes alive, and I can start the vehicle. Nowhere in the owners manual does it mention a need to provide any kind of battery charging system. What am I missing?
swtiming8
Wayne
Mishawaka, Indiana
Focus
Charge line from RV to Maverick
Suptrack
Maverick 24
Coming off your 7 pin on the RV into an installed receptacle on the Maverick, in the front bumper where the baseplate sits, wires coming off receptacle go to the battery. The RV is charging your battery when it's running. I have it on my Honda Fit right now, works great. I'll be having one installed in my Maverick when it arrives. The line from the 7 pin to the receptacle has to be made to attach on both ends. Hope this helps !
Mrk
Yes, these details help. Now to identify exactly what pin from the 7 pin RV plut equates to the six pin on the Maverick receptical so that I can run the wire from that exact pin to the battery. Alos, I've read about dioeds and fuses/breakers on this specific wire feeding the Maverick battery. Any comments on this matter?
Suptrack
Maverick 24
I can try and send you a picture of the receptacle ( dioed) that the line coming off the 7 pin connects to. I'll also send a picture of the line. Unfortunately the RV is in storage and I can't illustrate the connections
a***h
Al
Richfield, Utah
2026 Maverick Lariat, 2026 Lexus NX350h, 2020 F-150 King Ranch
I have wired F-150s, Rangers, and my Maverick all for flat towing behind my motorhome. All of them do indeed require charging from the motorhome. I can't send you information right now, but if you're interested I can forward pretty much every thing you need later? Just advise. :unsure:
Suptrack
Maverick 24
I'll send pictures either today or tomorrow.
Suptrack
Scenicgene
Gene
Scenic, AZ
2024 Maverick
I ordered a charge line kit from etrailer. Made by Roadmaster, I think about $35.00. It shows which pin to use on you 6 pin plug on your Maverick. Kit comes with wire, connectors and a relay with instructions. Simple install.
Nitroman
Paul
New Braunfels, TX
2024 Lariat Hybrid
I'm installing the charge line kit as well. My Maverick's Positive connection post under the red plastic cover does not have a nut. Anyone know what thread it is, so I can go buy a nut?
Get specs of the threaded post from your Ford dealer parts department or one of online Ford parts sellers
Nitroman
Paul
New Braunfels, TX
2024 Lariat Hybrid
Good call. Called a nearby dealership and evidentially it is an M8 nut. Unfortunately, they have none in stock. Calling around to see if other dealerships have one.
Suptrack
Maverick 24
I can try and send you a picture of the receptacle ( dioed) that the line coming off the 7 pin connects to. I'll also send a picture of the line. Unfortunately the RV is in storage and I can't illustrate the connections.
Suptrack
Maverick 24
I don't know how to add the pictures to the forum. Send me your email and I'll forward them to you
Suptrack
Xbbqpitmaster
Full Time Gypsy
2024 Ford Maverick XLT
You do NOT have to buy a nut from Ford. Just go to any quality hardware store and they should be able to fix you up. And a lot cheaper.
