Cleaning engine compartment
crheyne
northern California
2022 1st Edition Lariat, 2024 XLT both hybrids
Anyone else who cleans under the hood? Looks of stuff that makes it difficult but I hate to pop the hood and not see clean. I mostly use Simple Green.
2022 Lariat hybrid. First Edition
Tbone289
Be careful with Simple Green on aluminum parts. It will cause them to corrode if not rinsed off completely.
I use compressed air under the hood every few weeks and sometimes wipe down with a damp cloth. Nowadays with the under-engine trays, they stay pretty clean.
Chaseman17
Chase
Pennsylvania
2015 Mustang GT
Use leaf blower for loose debris and dust, rinse with pressure washer (hold nozzle a few feet away to avoid too much pressure), soak with simple green for about a minute, use brushes to scrub lightly across the entire engine bay, rinse again thoroughly, use leaf blower to knock off most of the pooling water, cover entire engine bay with Koch Chemie Motorplast, close hood and walk away. Check hood after an hour and look in amazement that the Motorplast has cured and the engine bay looks brand new, no drying required.
The whole process takes me about 5 minutes, not including the dry time. I will usually wash my truck after I clean the engine bay so the Motorplast can do it's thing while I'm washing. The stuff is an absolute miracle in a bottle.
Toddman45
St. Louis, MO
Yeah the Maverick seems to allow a lot of road debris gravel sand and whatnot to get in the engine compartment.
Like others mentioned for now I use a mixture of my mini Ryobi blower and a air compressor. When it gets dirty enough that I can't wipe it down after a car wash with a damp towel I'll hit it with a mixture of Dawn and water deluded. Then dry it with the blower and the air compressor.
Tbone289
A pressure washer is the last thing I would use under the hood.
MavChris
Macomb Michigan
23 Maverick XLT, 22 Bronco Sport, 19 Flex SEL
I just use compressed air and wipe down accessible surfaces with a damp towel. Just for my peace of mind I avoid spraying directly with hose or especially power washer. Moisture is not your fried considering all the electronics and wiring harnesses around the engine compartment. I've seen so many mechanics post videos tracking down electrical problems caused by corrosion inside sealed connectors and fuse distribution boxes.
svogt302
NJ
I wipe it down....
Little boy blue
Okeechobee FL
1995 ranger but getting a 2024 Maverick.
🤔 I never heard of Motorplast, where can you buy it?
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
My motor washing since 1970s
1st. Start motor
2nd. Spray all parts on motor with
Gunk original
3rd. Wait 7 minutes
4th. Pressure wash motor
5th. Let run for 15 minutes till dry
6th. Turn off and restart
7th.. Wax fenders and hood to
Clean off overstay
8th. Spray Armour all on engine
9th. Done
svogt302
NJ
I still mess with 60-64 Ford FE motors... 🤣
