Check your Tire pressures!
Ribwich
Kevin
NH, USA
Ford Maverick, Mitsubishi Lancer Evolution X
My XL gives me the individual pressures in the app at least...not sure about in the vehicle.
The XLT with Fx4 shows all the tire pressures on the dash but I think you have to enable that screen in the menu.
Nighowl2000
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
If the dealer didn't check pressure during prep they probably didn't do much else it may be worth checking lug nut torque also. I know Bronco Sport and Escape have had complaints of none being equal or at torque. I just recently checked my mothers 21 Escape that should have been 100ftlbs highest was 88 some were as low as 70.
Good idea
Lone Star Proud
William
Central Texas
Ford Maverick XLT
Got my maverick over the weekend and when I figured out the TPMS system it was at 42psi!!!! Door sticker says to be at 35psi.
That also helped the hood flutter. Had to realign the hood (4bolts) as it was off.
The 42 psi was in honored of the just announced mpg rating given the hybrid by EPA.
JohnHartshorn
Metro St Louis
21 Toyota Sienna XSE - Mav Hybrid XLT LUX Area 51
My Sienna had 42psi (Supposed to be 36psi) as delivered too! As someone said above, that's how they're shipped. I can't argue about my dealer missing it since I literally bought it off the delivery trailer.
Larrythelunatic
Larry
Massachusetts
Max pressure will be on the tire sidewall. That should be a cold tire reading. The difference between that reading and the door reading will mean a difference of 5+/- mpg. Ford would like to see the higher figure, obviously. So they inflate to the higher figure. Also, if there is a slow leak, the truck gets a longer period of time to make it to the dealer before it is noticed, and maybe needs attention.
I always inflate to the higher figure, only at a HOT tire temp. Better handling on the street, better mileage. Learned a long time ago to NOT make this a cold tire reading, as you will gain a few more psi at speed, potentially dangerous if you meet a pothole. And as the tire ages, it will actually split between the treads. (Don’t ask me how I know!)
Can add more to your statement "had to realign the hood (4bolts) as it was off"? How did you determine it was off and was realigning easy to do by yourself? Thanks
I took "It was off" as in "He had taken it off" maybe like others have taken things off to see what was "behind" it.🤓
kxtrain
Alex
Idaho
I thought the same thing until I looked at the max psi on the tire and it said 50 psi. I had the perelli with the fx4 package. Sounds like they met in the middle 😄
CenTexMav
Clint
Previous: Subaru WRX, Challanger RT, RAM 1500
my XLT w/lux shows the individual temps as well. All 4 of my tires were different when I got the truck. LOL... the front license plate holder was also upside down.
Sjbuck2021
Scott
2017 Frontier /2018 Acura RDX
Getting really disappointed at Ford quality control. Hood alignment....really?
Sjbuck2021
Scott
Mine were in the 40s+ when I checked mine! 🤯🤯🤯🤯🤯
Max tire pressure for my Michelin is 45PSI
Don't go by whats on the tire. Go by whats on the drivers side door sticker which I do believe is 35 psi. cold. Also don't trust whats on the display. Buy a good tire gage.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
I would like the softer ride at 35 psi instead of the 42 psi as received. But, the question is if I lowered to 35 psi, how much loss, if any, in mpg?
TIA!
Sjbuck2021
Scott
I just don't understand why everyone is hyped on over inflating their tires?
aspect
BC, canada
XLT Lux FX4 2.0 4k
Vehicle uses less fuel / accelerates faster
Firmer ride
Less tire wear (smaller contact patch)
I usually inflate mine a bit higher than the spec (~40psi) and will top up when it gets below the spec, but usually I've swapped tires by then.
Skisail
Ohio
Audi A4 Avant
The max pressure on the tire has nothing to do with the correct pressure. The pressure on the door jam (plus or minus 3 or 4 lbs, at your option) is the correct answer.
Just google for 2 minutes and you will see the truth.
