Check engine light came on -- what to do?
BensNewMav
Ben
Maine
2023 EcoBoost
Check engine light just came on. Is there some diagnosing that I can do before having to take it to the dealer?
Sometimes the Ford app will report some of those DTCs with more details.
Otherwise free scanner read at most parts places it seems. In hopes they can sell you something.
Otherwise no.
El Kabong
Carnation, WA
I do hope that this is all covered for you by the emissions warranty.
The hybrid has a pressurized tank system so it could be the evap purge valve or the pressure release stuff. What happens when you open your fuel filler flap after the vehicle has been sitting in the sun for a while - does it just pop open or does it take a couple of seconds to open?
The truck has 30k on it, and I have the 10yr/100k warranty, so I think it'll be OK. Going to the dealer's early on Monday, bringing a book and a lunch.
Hope you don't need dinner and a blanky & pillow.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
Code readers are so cheap these days, go but one. Easy way to be kept from shady dealings.
El Kabong
Carnation, WA
Yes, but - the cheap ones don't always work for what you might need. I have some older Bluetooth readers that don't show me the hybrid stuff like HV battery voltage or SOC.
The cheap ones almost only do OBD2 basic DTC's.
There are many modules on most vehicles now that hold their own code detail - only the MIL is told to display.
Maybe the DTC gives a clue as to what module, but no details as to what issue.
But as other threads have shown, basic DTC can also give a generic code that basically means this is Ford specific, or whatever make you have.
Or won't show any DTC's despite the MIL on.
Or worse - there's actually 6 DTC's, some module specific, but your basic OBD shows you 3 - and you think that's it.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Yes, I looked and it's still there.
Took it to O'Reilly's, they checked it with an OBD and it threw a DTC PO496 -- EVAP system high purge flow. Next stop is the dealer.
Do you like to "top" off the tank?
Mavster Mechanic
Hybrid
Flashing or not flashing?
Someone will correct me if I'm wrong in about 30 seconds.... but.....
I believe a solid light is not urgent. You can check up on it when convenient
Flashing is urgent and you should check on it right away.
Over 12 hours. 🤔 I guess you're not wrong. 😁
