- First Name
- Gary
- Nov 9, 2025
- Grand Canyon, AZ
- 2025 Maverick XL Hybrid AWD 4K Tow Package
- Engine
- 2.5L Hybrid
That would be true if the air WAS colder, but in most cases, it isn't...
The "cold air" way back in the day was from the front of the car, where most cars for decades now get their combustion air from, rather than from a tin can on top of the engine..
The new induction system doesn't chill the air, so at best, the only potential reduction in temperature and increase in density would be from the difference in routing the tubing vs. the stock config.
Considering that the factory induction system is plastic, which is an insulator, how much reduction will there be in temperature and a corresponding increase in density to the air running through from a short run of plastic, vs. a different run of plastic.
Likely, not much, considering that either induction component will live under the same hood, and a lot of air is traveling through the engine compartment, making the temperature homogenous while driving, which minimizes any potential beneficial effect of the intake plumbing routing.
