Dad
Mine just arrived and plan on installing it this weekend.
Mine arrived yesterday, too! Now searching this thread for install instructions. Speaking of... anyone know how to remove the black cowling around the mirror?
Also, I've seen where folks have wired the mirror to existing wires inside the cowling (used for the sunroof) and others have run cables down to the passenger side fuse box. I also have a dash cam that is already wired to the fuse box, so if I can remove the cowling, tap into the cam wiring and hide all connections behind the cowling, that would be sweet.
Eagle11
Valley of the Sun
That is my goal with the dash cam, to me, that is the best and easiest.
  • Like
Reactions: Dad
Eagle11
Valley of the Sun
If it's like mine, black w/white stripe is switched power, Black is constant power. My ground wire had a circular end so it was obvious.
YUP thank you !!!!
clavicus
This issue is the reason why I ran a separate power line (either 16 or 18ga is fine for dashcam/mirror load) from fuse box to dome light cavity, and THEN tap this new power source for both the dashcam and the mirror power. That means just one run from the fuse box, instead of one run for each device, or tapping into existing wires for either.
Dad
You're way ahead of us it seems! I think I can cleanly tap the dash cam wiring and tuck any wire mess under the mirror/light cowling. Thanks for confirming.
Eagle11
Valley of the Sun
OK, I was able to install the Kia Mirror and tap into the wiring harness for the Dome lights. I watched a video on YouTube, and in the video, I watch the person telling which wires to use... Complete success. Had to make a run to O'Riely's to get wire connectors.
There are three "clips" holding the black cover on.
Ford Maverick Cheap auto-dimming, homelink mirror 54D35080-240F-4074-85FA-EE52F70346A9_1_105_c
Ford Maverick Cheap auto-dimming, homelink mirror 6E481F50-A582-4E7D-8F14-E8107979AA9C_1_105_c
The second photo shows there is a "tether" connector that holds the panel (I couldn't figure out how to undo it)
We also took the cover/panel for the Dome light (I have a sunroof) down and disconnected the wires. I tapped into the wires for the dome light. The video I found did the same thing on another Ford vehicle and the same wires were there...
Ford Maverick Cheap auto-dimming, homelink mirror BE549D81-4210-4BBE-849B-F273EA0B27E3_1_105_c
The black wire is your ground, the Purple wire is your (switch power) Yellow/green (last write on your right) wire is your constant power.
Ford Maverick Cheap auto-dimming, homelink mirror 15AEEA64-CF26-4960-9834-E63871AA6612_1_105_c
I used about a foot of the wire that came with the mirror, it was over kill but when everything is tucked back in place there is plenty of space.
Ford Maverick Cheap auto-dimming, homelink mirror 20CD805E-BAED-4D19-8B1F-ACA36A32CF08_1_105_c
In this photo you can see the green light is on the mirror, so the mirror is getting power. VERY simple and easy... Truly I could do this in about 25 minutes from start to finish.
Ford Maverick Cheap auto-dimming, homelink mirror 1ACDCC5A-0135-4DE1-A902-1425BF5683CF_1_105_c
Completely put back together looks factory.
Ford Maverick Cheap auto-dimming, homelink mirror 4ED45F25-0C9E-41EE-90A1-16B1020878DE_1_105_c
Took a picture once the Mirror was calibrated to show the compass. Now, I need to program the homelink.
Can't believe how inexpensive this was from Kia.....
Ford Maverick Cheap auto-dimming, homelink mirror 23A999F3-9779-4B59-8254-F77D3E430585_1_105_c
This is what I used to connect with the wiring harness.....
@Dad
Dad
@Dad
Outstanding guide on how to do this! Photos and narrative much appreciated. I like how you used existing power source without running more cables down to the fuse box. Thank you for paving the way for others like myself who needed guidance. One more favor ... can you post the YouTube link?
Eagle11
Valley of the Sun
No problem, and thank you for the kind words. It was straight forward.
You ask and you shall receive.
Wawesson
Wayne
Maverick Lariat FX Alto Blue
@Dad
Did the Homelink work? If not. Mirror has Version 3 of Homelink. Need Version 4 to work on newer garage door openers. There is a module put out be Chamerlin that plugs into AC in garage that communicates with V3 and V4. Very easy to correct so the mirror works. Cost about $30 on Amazon.
Wawesson
Wayne
If Homelink not working, look on back of mirror and see if it says VHL3. Version 4 says VHL4.
Eagle11
Valley of the Sun
Yes, Homelink works our opener is about 13 yrs old
Eagle11
Valley of the Sun
Did u install yours yet?
Dad
No, not yet. Too many other projects going on right now. I did find a video on the install, but I haven't had an opportunity to look at it.
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
Mirror installed just fine tonight - one issue though, the homelink buttons don't seem to do anything at all. Even holding buttons 1 and 3, which should normally reset homelink doesn't do a thing even with holding for over 1 minute. Did anyone have this issue with their mirror?
adawalli
Adam
I followed this image above and I am only getting 10.3v out of that purple/white left wire on the left...anyone else having a different reading?
