Changing to AGM
JimInWI
Wisconsin
2024 Ford Maverick, 2024 Georgetown GT5 31L5
So, Amazon says that this does NOT fit the Hybrid Mav. Are they just delusional?
Yes, they are delusional. The battery fits and has been installed by many members of the group including myself.
dennish
Goodyear, AZ
Ford Maverick Hybrid Lariat :-)
I got this one and it sits in my hybrid today and has worked for over a month with no idea sleep issues - Also said it wasn't for it:
https://amzn.to/4jpiyXr
$30 off with coupon. Ships and sold by Uplus so I assume same rebadged battery.
Deano777
Dean
Southern Oregon
2024 Hybrid XL w/360 (Poverty Edition)
JimInWI and Dennis, thank you both! Ordering one now!
Amazon is correct in that the battery does NOT MEET THE EXACT SAME OEM SPECIFIC SPECS. it could be and is taller even if only 1 millimeter but is (3/4"?) taller. Hey it may have more AH? WOW = Install at own risk. Does it meet the OEM vent pressure?
JimInWI
Wisconsin
Careful! Somebody might take you seriously here!! 🤣😂😉
Deano777
Dean
Southern Oregon
I replaced my battery today. Thanks for the help of everyone. But I believe that I broke the vent attachment. I see that the consensus is that the AGM batteries do not need venting, so I will not be very concerned. Still struggling with the internal mounting of the battery.
Ft Myers, FL
2024 Maverick XLT
I just replaced my battery with an H5 Odyssey ($275 with a coupon). It's only been 2 weeks, but so far, so good. I appreciate all the advice that y'all had to share. I didn't find many pictures of the process, so I took some myself. I wanted to video it, but ran into some hurdles, so I only got these snapshots.
Caveat: I'm no expert and I just pulled on stuff until it worked. Managed to get it all done in under 1 hour without braking anything. Followed this up with the battery reset (ignition to "on", high beams 5x, brakes 3x, see flashing light, let truck sit 12 hours).
Pics keep getting shuffled when I post here. The correct order can be seen here: https://www.facebook.com/share/p/1LAoGWQrZy/
Ford Maverick Changing to AGM 20250429_203026
Ford Maverick Changing to AGM 20250429_203040
Ford Maverick Changing to AGM 20250429_205024
Ford Maverick Changing to AGM 20250429_203051
Ford Maverick Changing to AGM 20250429_203056
Ford Maverick Changing to AGM 20250429_203102
Ford Maverick Changing to AGM 20250429_203108
Ford Maverick Changing to AGM 20250429_203156
Ford Maverick Changing to AGM 20250429_203247
Ford Maverick Changing to AGM 20250429_203354
Ford Maverick Changing to AGM 20250429_203347
Ford Maverick Changing to AGM 20250429_203635
Ford Maverick Changing to AGM 20250429_203857
Ford Maverick Changing to AGM 20250429_203906
Ford Maverick Changing to AGM 20250429_203910
Ford Maverick Changing to AGM 20250429_204309
Ford Maverick Changing to AGM 20250429_204313
Ford Maverick Changing to AGM 20250429_204938
Ford Maverick Changing to AGM 20250429_204840
Ford Maverick Changing to AGM 20250429_204844
Mikes22Mav
Orange, CA
2022 Hybrid Lariat
Do you know if there any YouTube videos showing how to remove the plastic to get better access to the battery. I can't follow the pics without and explanations.
Mikes22Mav
Orange, CA
2022 Hybrid Lariat
Removing plastics around the 12V hybrid battery.
Thank you, Glen Baker!
I tried for a half an hour to get the plastic out and couldn't.
I know I am not stupid but what the heck am I doing wrong?
I think the battery is in the way of removing the plastic.
Do I have to remove the battery hold down bracket to wiggle the battery out of the way to remove the plastic? And yes I see in the video he does remove the battery bracket to remove the plastic.
Got to pay attention!
And the dealer never connected the vent tube on the 4th battery they replaced. Morons!
The largest dealer in Orange County California can't replace a battery correctly.
I don't think it will hurt me to say it's, David Wilsons, Villa Ford of Orange.
I've never have had to remove my battery.
When the time comes and it will.
I will have to refer to the video.
cyberdog
Ray
2023 Maverick Lariat Hybrid
With the stock battery, it only requires a slight manipulation of the panel to remove it. (Keep in mind that they thankfully didn't make it one big piece.) Installing over a larger H5 AGM does require a bit more dexterity or patience, however it really wasn't that difficult. I have better spatial visualization than most, so it only took me a moment or two to visualize how to move the panel back into place over the H5 battery. - It helps to not reconnect the battery until you've put the panel back into place, which gives you a bit more room around the top edges of the battery.
Quite frankly it was easier, quicker, and less costly than taking a morning off of work to sit at the dealership for a replacement flooded cell battery at the time. Mine's been installed nearly two full years, and other than mis-wiring my dashcam to a constant 12v circuit (I neglected considering the 1st fuse as Fuses 1 & 2), not a single deep-sleep since installing the Weize H5 AGM.
Yep, the "dual" fuzes are different.
