generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
Maybe I'll start a new trend... tow your garage with you. Park, unhook, lower the corner jacks... and pull right in!
(Disclaimer - the trailer is aluminum so only weighs 2680 lbs empty)
(Second disclaimer - tow this size trailer on the highway at your own risk)
Ford Maverick BYOG (Bring Your Own Garage) - Trailer Towing IMG_1677
Ford Maverick BYOG (Bring Your Own Garage) - Trailer Towing IMG_1675
Jeff D.
Duluth, MN.
If you parked the truck inside the trailer, how would you get out of the truck? Even with the windows down I think it would be tough, and no matter how much butter I lathered on myself, there's no way I'd be able to slip out the rear window. ;)
Waterick
Laurens county SC
Need custom built low boy with appropriate side door.
generalmgr
generalmgr
Wes
Clarion, PA
The Mav is 73" wide, the trailer interior is 95"... plenty of room if you skip breakfast :ROFLMAO:
TRUCKHEF
SOCAL
22' Ford Maverick XLT
What’s the tongue weight on that bad boy? Looks like you got some squat
Dad
Now that's a good question. Here's how one guy solved it.
generalmgr
generalmgr
Wes
Clarion, PA
Hitch weight is supposed to be 288lbs empty. I'm parked in a sloped lot, near the drain, so it looks a little more squatted than it really is... but yeah, it's a big trailer, hook it to a Mav with extreme caution lol.
Fmp0926
McLeod
2022 Ford Maverick XL
Wes, why does he have to back up to get out? I don't understand.
He backed up so he could open the driver's door wide enough to step out. Of course it only worked because he had a compact car with a manual trans so he could roll it forward again to close the door.
RichardCranium
R
I want to see the pictures of the maverick parked in the trailer. 😆
No Brand
Max
'24 Lariat BAP, '20 F-250 BAP
Needs WDH...
Deweyordeweynot
Dewey
Macomb, MI
Reminds me of that Top Gear episode with the 3-wheel Reliant Robin (I think that's what it was called) and the car would tip onto its side on turns; the driver would climb out the other door, push the car upright, and drive off.
notfast
Los Angeles CA
Realistically, roll down a window (might be easier to crawl over the interior and jump out a different window without a steering wheel in the way). You could also park as close as possible to one side and see how far you can open a door (probably a rear door since they are shorter front-to-back).
Some trailers can be optioned with a large flip-up escape door and flip-down fender on the driver's side to make the loading/unloading process easier.
Needs WDH...
If it was loaded, perhaps. At 2680lbs empty, even 15% would be 402lbs. Well within the payload limit.
Towing on a windy day will get real exciting!
Especially with a lightweight large box trailer.
