- First Name
- David
- Sep 17, 2021
- Wakeman, Ohio
- 2020 F150
- Engine
- 2.0L EcoBoost
Finally........I dropped the ball on this product for months. We've been waiting for the turbo to be built now for 8 months or more, once that is done we will get on the down pipe too.
Anyway, this is the latest release, the Vented Pro can. This will 100% eliminate ANY and ALL oil, fuel, water vapor from being re-circulated back into the turbo inlet. The standard catch can does a killer job of this and is closed, so SHOULD pass emissions in every state and be zero issue with any dealership. This newest version eliminates the inlet to the turbo inlet and adds an additional port where the oil filler cap is. The oil filler cap is removed and replaced, don't worry, this doesn't make oil changes harder, the new fitting turns with the hose on and oil can be added easy. The factory inlet to the turbo inlet is capped.
This will eliminate 100% of the crankcase pressure and capture 100% of any oil/vapors in the catch can.
We've change the original mounting location to make the install easier and universal between the non-vented and vented catch cans we offer.
All new catch cans will mount in this same location, pictured below.
The new Vented Pro can is $329 plus shipping.
