- First Name
- David
- Sep 17, 2021
- Wakeman, Ohio
- 2020 F150
- Engine
- 2.0L EcoBoost
For anyone who has followed this. This is an edit of the original post that was here.
The factory fittings at the intake and valve cover are a complete pain in the ass to remove. Everyone is having issues and the fittings are breaking. The other issue is finding an aftermarket fitting for the valve cover, it's an odd short fitting we haven't been able to locate.
Our catch can kits will no simply re-use the factory fittings at the intake/valve cover.
DO NOT ATTEMPT TO REMOVE THE FITTINGS. Simply take a sharp knife, gently slit the factory hose and then pull it off the factory fittings. Then push the supplied hoses from our catch can/oil separator back onto those fittings. It makes the job much quicker doing this.
Thank you!
Thank you!
