Bump Step
Darklyter
FL
XL, like me lol
www.sparebumper.com
I have it on this truck, carried over from my last truck. License plate is covered more that the weathertech item, but it's not really 'covered' since you can see it at different angles.
Equator Guy
Topsham, ME
2023 Maverick XL., 2015 Rav4. 2012 Suzuki Equator
www.sparebumper.com
Hello Darklyter: If you get a chance can you post a picture of your truck with the sparebumper installed? Awaiting my XL (in production) and weithing my options.Thanks!
swtiming8
Wayne
Mishawaka, Indiana
Focus
Cops must have nothing to do in your area. I don't even use a front plate anymore. I will have the 24" bump step on mine.
After reading all the horror stories about Mavs being rear ended and totaled for what looks like minor damage. I ordered a weather tech bump step. I am having second thoughts now. Mostly because it looks like it will block the view of the licence pate. Really don't like being pulled over by the cops.
I ordered the WeatherTech bump step as well but I felt the 12 inch would work just as well as the longer ones since they all attach via the tow receiver that size will not matter anyway
BeachBum
PA
2022 Area 51 AWD Maverick XLT w/ Lux
I have some wicked LED's that flash 3 times then light steady. I'll have to see if I can make some work in the 3rd brakelight.
@LSchicago I found these on another thread somewhere on the forum: https://www.amazon.com/dp/B09SGB672J
Ordered and installed them a couple days ago. With this kit, you'll get two white LEDs to replace the cargo lights, and two strobing red LEDs to replace the single 3rd brake light (you'll have an extra).
Johnkn
MD
They may help a little in a very slow speed impact, but you need to ask yourself whether you want to take all that energy from a higher impact that the Mavericks rear end is designed to absorb and mitigate and then concentrate it into a smaller area rather than allow the rear end to do what’s its engineered to do (and spread to load to best absorb it safely).
Good luck
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
Is there any aftermarket bumper or modification where I can have steps on the back corners of the bumpers like bigger trucks?
boe757
dave
minnesota
f150, camry,
take a look at this video : may help resolve the issue
K5Blazer
Colorado
2023 Maverick XLT
Why?
Are you extremely short or something?
The big trucks use those because the average person can’t reach over the very high sheet metal and reach the bottom of the bed.
Its likely not a problem with the Maverick unless you‘re 5’ or less.
NJBob
NJBob
New Jersey
Good luck
Yes totally understand the thought. The hitch anyway is very exposed. My thoughts are it would probably take that impact anyway. Short thoughts low impact parking lot issues will most likely work. Higher impact may be better may be worse. I did put it on today and like seeing it on the back up cam. So you know how close you can ger.
LSchicago
Lloyd
IL
Thanks, but I own an LED lighting store. I'd rather use what I have. These would be a good option if they strobe 3 times, then light steady. Continuous strobing red 3rd brake light is illegal.
Darklyter
FL
XL, like me lol
RE- posting since the original pics were not edited correctly... I hope these help. The license plate is not 'covered' . It's viewable from almost every angle .
Ford Maverick Bump Step 20230813_144805
Ford Maverick Bump Step 20230813_144817
Ford Maverick Bump Step 20230813_144825
Ford Maverick Bump Step 20230813_144647
Ford Maverick Bump Step 20230813_144712
Ford Maverick Bump Step 20230813_144651
NJBob
NJBob
New Jersey
My dealer had this as a mandatory add on which I refused. But was intrigued by the idea. Esp at a 400 buck cost.
Flight Test
DFW
Corvettes
A new nickname for your truck..."Hammerhead". ;) Reminds me of a Hammerhead shark. 😁
BeachBum
PA
that's what they do, strobe 3 times, then light steady
Edit: that's what the red LEDs do, strobe 3 times, then light steady
Ford Maverick Bump Step 1691956420664
Equator Guy
Topsham, ME
Thanks for the pictures and detailed measurements! Will definitely consider this option if/when I get my truck.
