BradH
Brad
St. Louis, MO
2023 Ford Maverick XL
A few months ago I was at my friendly big box store and passed by the section with the temperature and weather instruments they have for homes. Was looking at them and got an idea. I bought their cheapest package, made by LaCrosse, which has a small display unit to show indoor and outdoor temperatures, and a battery-powered remote sensor unit for reading the outside temperature. Normally you'd keep the display in your house somewhere, and put the remote unit out in the yard. After I got home I put the external sensor in my "tool tub" (cheapo plastic container with a few basic tools) in my Mav's bed; then the display unit fit nicely in the cell phone holder in the center console.
Ford Maverick Bed temperature readings from temperature sensor installed in the bed IMG_4687
The top number is the "outside" temperature, i.e. temperature in the bed. The bottom number is the "indoor" temperature, or in this case the temperature in the passenger compartment. For reference my Mav is Cactus Gray; and the bed has Line-X SIBL plus a MostPlus hard trifold cover (in black).
The information I'm getting from this has proven to be much more interesting than I initially thought it would be. During our blazing hot summer in Missouri, bed temps would usually get up to about 120 degrees or so, while the cabin was usually up to about 110-115 degrees. Now the picture above is a weird aberration; the truck was sitting at my church parking lot one afternoon, and the bed "only" got up to 109.6, while the cabin was 121.3 degrees. This past week, with the cool-down in the Midwest temps on both have been showing in the 70+ degree range.
Anyway, I'm finding this to be pretty useful and it wasn't expensive, I think maybe $30 or so for the unit if I remember right. Like all the old PSA ads used to say, don't leave your pets or kids (or adults, lol) unattended in a hot car! But also, it's made me realize how hot the bed can get, and to consider that for any stuff I put back there.
inline_five
2023 Hybrid XLT
I'm in NC, and saw 145° one day. I now put shades in all windows to reflect the sun out, although that doesn't seem to do a lot.
I try to park in shaded spots if I can. Fortunately, I garage it except for maybe 35-40 days a year.
To lower temp inside cabin you need window tint with 99+% IR(Infra Red) block. (You can buy less than 5% visual blockage with 90+%UV and 99+%IR blockages)!!!
inline_five
2023 Hybrid XLT
I use foil backed shades that block 100% of all light and IR. Basically hermetically sealed from light lol.
Custom Fit Car Side Window Sunshade for Ford Maverick - Set of 4 Front and Rear Sun Shades, Reflective UV Heat Shield, Real Aluminum Foil
https://www.amazon.com/Automotive-Reflective-Sunshade-Compatible-Maverick/dp/B0C8VCS2VC/
Fun fact all tint regardless of % is 99.99% UV. Almost any plastic is.
Mavster Mechanic
Hybrid
I would think in most scenarios the inside of cabin would be hotter.
Greenhouse effect and all.
Mavster Mechanic
Hybrid
As is factory glass.
Edit: factory glass blocks nearly 100% of UVB and 75% to 85% of UVA.
Just remember UVB causes "Burns".
So advertised "UV" blockers, at best, block that last few % .
Drive all day, 7 days a week.
You won't get a sun burn.
(With windows up of course.)
But I guess UVA could over time
Be harmful.
inline_five
2023 Hybrid XLT
So advertised "UV" blockers, at best, block that last 1% that was basically harmless in the first place.
Factory glass actually isn't 99%. The windshield is because it's laminated. The windows are around 85%. Yes I own a UV meter.
Mavster Mechanic
Hybrid
Well we were both right.
All window glass blocks UV-B rays.
Side windows block about 75% of UV-A rays.
Keep forgetting there are two kinds.
MaverickDragon
Grand Canyon, AZ
It might be interesting to see what the differences are for different bed cover types e.g. metal vs. vinyl vs. fiberglass polymer types.
inline_five
2023 Hybrid XLT
There's actually three - UVC as well.
It's variable on manufactuer - Tesla blocks the most UV from the factory. IIRC Mercedes was also much higher. The rear factory tinted windows on the Maverick don't block any more UV than the front windows.
ScottDT1
PNW
Yes
Much more effective if using shades, (I learned from my camper van with it's huge windows,) is an exterior cover. With the interior ones, the heat is already created and is just sandwiched between the glass and the shade to be radiated into the cab.
