Backup camera rain hood?
Whatcolortochoose
Thomas
Hampton roads
2023 Royal Enfield INT, 2006 Honda Shadow 1100
It makes me miss my VW that had the camera hidden behind the emblem until in reverse. It was always clean an clear in all weather.
kkreit01
Korey
Olathe, KS
'22 Maverick, '17 Grand Cherokee Limited 4x4 V6
I've never driven a vehicle where the rear camera doesn't get dirty when driving on wet roads. SUVs, trucks, cars, all are bad.
AL-Tess
AL
Nor CA
2024 Maverick Lariat
v1 needed trimming, it still leaves a vignette, but I will test and see if this helps direct water away from it.
If this doesn't work, I am going to completely rebuild the badge and 3d print one that matches my black maverick better.
Just wondering, how the hood has been working out or have you moved onto the rebuild the badge stage?
MrShadetree
Missouri
None
I saw a video somewhere that said rubbing the lense with a cut potato will make the lense hydrophobic. I don’t know if it works. Got a spare potato?
AL-Tess
AL
Nor CA
Sounds crazy enough that it just might work.
Marty
2026 Ford Maverick Tremor
Really ?
Jeez~o~Pete,
You guys are ate up with it!
Back in the day we actually had to turn our heads around and look.
PMSL
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
The problem is not that rain falls onto the camera, but that the vehicle has truck aerodynamics. The water generally blows up the tailgate instead of down from the top. A rainshield on top will just create a small air-pocket that will trap even more dirty water.
tpollauf
Toledo/Port Clinton, Ohio
1992 F-150, 2009 Pontiac Vibe GT, 2026 Maverick Lariat Hybrid
Maybe just make it a daily habit to do a quick "swipe with a rag" over the lens before driving off! This way it should be clean for each initial drive.
Vluc
Vince
Western Pennsylvania
2025 Maverick Lariat
There is a solid digital device that we all carry on the end our hands that do a wonderful job.
cyberdog
Ray
2023 Maverick Lariat Hybrid
Dumb question, but wouldn't one of the tailgate emblem rings extend the trim out far enough to keep most of the water off the camera? - Seem like they'd basically accomplish the desired outcome?
Most of the time the drops are enough to both me when reversing, although maybe it's my compulsion of applying the hybrid(ceramic) wax to the emblem & camera, as well as the tailgate, which helps minimize the issue? - Or having the tonneau, or cab spoiler affecting the air flow against the tailgate?
