B&O Sub Hole Cover
todd92
I put a better sub in and removed the B&O sub. Has anyone 3D printed a cover for the hole? Right now I have a towel laying over it, I would like a better solution.
converseguy
2023 Maverick Lariat Hybrid, 2024 Toyota Prius Limited
It was easier for me to just leave the B&O sub in place. I have no other use for it anyway.
Toddman45
St. Louis, MO
Can't you purchase the OEM cover isn't it more or less like a foam plug?
Ford Maverick B&O Sub Hole Cover PSX_20241110_163946
oysterville
Oregon
2024 Maverick Lariat
I'm thinking about using Flex Seal tape.
that would do the trick. I was deadening various areas and just slapped a piece of Amazon basics butyl sound deadener over the hole with at least a half inch extra on any edge. 45k on the truck and no issues. ✅
Aaron F
Aaron
Sterling Heights, MI
2023 Maverick Lariat Lux w/ 4k and BAP / 2025 Maverick AWD Hybrid Lariat w/ 4k
I also just used extra sound deadening over the opening after removing it. I used the extra space from the removed sub for amplifier rack.
todd92
Thanks!
The factory part is cheap
interesting. did you install it? I've seen the metal plug on non b&o but didn't know you can order that.
newagecritter
Virginia
2025 Maverick
I used gorilla double sided (outdoor) tape and a piece of thin plastic. Easy enough and had it all on hand.
