Awd working or not
Joe Strummer
Squamish, BC
2024 Ford Maverick XLT Tremor
In the FX4/Tremor models, the driver can manually engage 4WD. The AWD version does not have this feature. The computer will decide how much power to send to the rear wheels.
Maybe try L instead of D when selecting gears.
lavaspill
I think the Tremor is the only model you can lock the rears.
My AWD screen shows all four wheels with power during any start from stop.
mine as well, but I haven't looked while in tow drive mode.
Derwood
Derwood
Buick and Kia
This is why I really wanted the Tremor or even the FX4. I can confirm mine pulls front and rear when towing up steep hills. Also I use the AWD lock to reduce the extra wheel spin the front will get on steep climbs.
As other have said go through the instrument panel menu to find the intelligent AWD screen and watch to see what happens with the rear wheels. Mine even engage in normal modes on pavement just when hard accelerating from a stop. Yours should aswell. If they do not have a passenger record the screen in a low traction condition and take it to the dealership.
Aside from that tongue weight could be an issue. Also I would put it in slippery mode and see what happens. It should work the AWD and cut a bit of power and work the brakes a lil on the spinning tires to send power to the gripping tires. But yeah try all the modes. Tow mode to me sounds like it would probably not engage AWD any more than normal mode.
If I understand correctly.tow modes main function is to keep the transmission from going into the lowest or highest range of gears to lessen the work it's doing while towing?
73ofalltrades
73ofalltrades
2024 Maverick
Thanks for your idea everyone. I will watch the intelligent track on the dashboard now that I know it has it and watch to see what it says.
73ofalltrades
73ofalltrades
2024 Maverick
Is yours an FX4 with 4k TOW or just AWD with 4k tow?? The AWD systems apparently operate differently between those configurations.
From my owners manual
Mine is just a XL with towing package
Maverickman74
Shane
Maui HI
Exactly. So it doesn't make the awd system work any better. The slippery modes or whatever other high traction modes you have, i'm only familiar with my Tremor, will get you more aggressive rear power transfer.
justiz00
North America
I turned on mud/ruts and sand/snow drive modes awhile back. I just used it in sand/snow, the screen shows the same if not more power directed to the rear wheels.
Montana
Me either. I've never tried pulling what I would consider close to my limit for towing up a grassy hill lol. I'm not really surprised it's slipping. The engagement is pretty slow and it could be that if it's in tow mode there is conflict in the PTU or it's reached it's limit. Lots of variables.
I wish we could see a video.
I've never tested the limits of the AWD system, but I've noticed in winter if it's not in slippery in icy/snowy conditions, it's noticeably slow to engage. The non Tremors certainly aint Subaru's 🤣
Snox801
Levi
Spring Lake Michigan
that's odd. have you looked in the intelligent awd status screen to see the torque split? it should be 50/50 anytime you start from a complete stop. but I actually don't think I've looked in tow mode.
Yes it does move power but it does so after it detects slip. Definitely could be a much faster system. I really notice it while off roading. You get that split second oh shit when the front wheels slip thinking then realize it’s not 4wd. Then the rear kicks in and it goes
Snox801
Levi
I may try the icy mode when I go off-roading next.
All we need is someone to crack the rdu code. So hopefully we can lock up the clutches more. And get that ptu to push power earlier. They did it with the focus rs rdu so I’m sure someone could eventually with this system also
bgn
WA
You'll run out of clearance and articulation before you run out of capability on the AWD.
Source: me, who has thousands of miles on forest service roads in all types of conditions.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
Put it in sport mode, it will be 50% front/back from the jump.
24Mave
V
Tn
24 mav awd
Was about to say the same. In normal mode it’s 99% fwd, was going around the turn the other day on a wet day and started sliding a bit, don’t think the rear even kicked in. So not much confidence driving in the rain/ snow.
played around with different modes today and sport mode looks like it engages it more often, which is good to know.
Also get a lot of torque steer when accelerating from stop in normal mode which is weird as computer should probably figure out what’s going on and kick in the rear.
