Automatic Parking Brake Applied
  • Thread starter Deleted member 35678
  • Start date
  • Watchers 1
Tbone289
MO
I always put the parking brake on before I shift to park, that way it's the parking brake holding the vehicle still instead of the transmission.
This is good practice, but if you come to a stop and keep your foot on the brake, it doesn't matter which order you do it in, (brake vs. park), the tension will remain on the brakes rather than the transmission. Tension would only be applied to the transmission parking pawl if you let your foot off the brake in park and it rolls slightly before you apply the parking brake.
My brother used to launch his boat and put his truck into park on the ramp without applying the brake, putting tremendous tension on the parking pawl. It drove me crazy.
OneAlienBoi
Kev
Utah
Explorer
I've literally never heard of someone turning their vehicle off and opening the door while it's still in drive, that's wild. The normal sequence of events is pull up, stop, with the foot on the brake, shift the vehicle into Park, turn the vehicle off, undo the seatbelt, open the door. That's how literally every single driver I've ever seen does it.
If you tried to open the door and turn the car off while it was still in drive during a drivers test, you would immediately fail the exam.
OneAlienBoi
Kev
Utah
Explorer
Why are you opening the door before you take off the seatbelt and turn off the engine? Yes, it’s normal for to go into park and at least on hills to apply the parking brake.
For hills yes, but mechanics have told me if you're parking on mostly level ground, leave the parking brake off. I don't like the little rock back and forth a car does without the parking brake, but apparently that doesn't hurt anything. Whereas using the e-brake every time you park can wear out the parking brake cable and other components prematurely.
Mr Pibb
Vegas
2024 Lariat
We don't have a parking break cable in the traditional sense, it's electronic. Though you could run into issues in the past with people who never used the ebrake and needed to.
AlsMaverick
Allen
Cincinnati
2024 Maverick Lariat FX4 w/4k Tow Build Date 12/5
Only a fool would purposely open the door of a running vehicle while in drive and then turn off said vehicle. What if the fail safe failed?
Not smart.
Ozarkbeard
You left out, set the Parking Brake (before you put the vehicle in Park).
Ryom
PA
2025 Lariat 4K BAP Eruption Green
I've never heard of a parking pawl snapping outside of abuse (routinely slamming it into park before the vehicle has come to a complete stop) or a manufacturing defect. Modern vehicles mostly won't let you break the transmission components by being stupid. I wouldn't mind the parking brake being a more tactile thing than a little pull lever though, I like yanking on the handbrake. It's still not any more trouble to finger the parking lever than it is to open your door while seat-belted.
Bigfoot7262
Wes
South Carolina
2024 Maverick XLT
While I don't see anything in OPs routine that could do damage, AlsMaverick has a point that IF something were to fail, say the truck doesn't recognize the door being open, that could defeat the auto-park & auto-brake.
I've tried leaving the vehicle in D and just setting the brake and shutting it off but some habits die hard
Guest
Do they still make you look behi
not so much the trouble but more remembering to do it.
So you are going to try to remember and make a habit of a whole routine to cause an effect you want, rather than just try to remember 1 step?
Because frankly if remembering is difficult on the parking brake to make into a habit - then you'll probably have some bad news on remembering this multi-step little dance, and you'll be dancing under the tire someday or forcing someone else to.
Guest
this is it. 1-800 Ford said it's designed to work this way as a normal exit procedure. Done. No more telling me about what's safe or habits with other vehicles or some boomer muscle memory steps you have been doing since the 70s! I just thought I could get an answer about if doing that was bad for the vehicle. Turns out it's not...I should have just started by calling the 1800 number.
