Auto Start/Stop 'feature'
ogreogre
Tennessee
2026 Lariat
I've had my '26 Lariat for five months and like it very much, but the one item that I despise is mentioned in the thread title. I want to get rid of it. From what I've researched there are two ways, (1)disable it thru Forscan or (2) install some sort of wiring harness thru the center console. I've looked at getting Forscan, as there are a few other settings I'd like to tweak, but after looking at YT videos it looks involved and complicated. Plus, I have a PC, not a laptop so I'd need the wireless version which runs $150. I'm mechanically inclined (but getting old fast!) but I'm hesitant to pull apart my interior. Are there any other options?
Two Ford dealers told me they wouldn't disable it, one said it was a 'safety feature' and one said it would void my warranty. I know that it's not on the '27 models, a sales rep told me it's no longer a law. But I looked it up and the EPA is no longer offering 'off-cycle' emission credits, so there's no longer any incentive for the manufacturers to provide that.
The two ways I deal with it - if I'm on a major road with lots of stop lights, I change to Sport mode and it's disabled. But I really don't like the Sport mode (most of the time), but maybe when I'm driving in the mountains. I try to creep up to red lights, hoping I don't have to stop. But I've found the most effective is not the press the brake pedal very hard, and the engine won't cut off. But that's not necessarily safe, and sometimes it cuts off anyway. But it's too much to have to think about. What really chaps me is when you're forced to stop, the engine cuts off, but you release the brake quickly and your truck cuts off and re-starts in a three second span. One side of me says eff-it, the battery and starter or built for it. But I find it annoying and want to nuke that feature.
Thanks for listening. Chime in if you have any suggestions to bypass it or which option is best or how to deal with it. Snarky comments are also welcome. But seriously, should I find an independent Ford/Mazda shop that's good with Forscan? And is there any possibility that I could void the warranty from by-passing the setting? If I find someone who can do it through Forscan, I'd also like to disable the audio seatbelt warning and drop the temperatures of the seat warmers by 2 degrees Celcius and 1 degree for the steering wheel.
mwelby
mwelby
New Mexico
2025 Ford Maverick 2.0
After you start the engine, just press the start stop button to deactivate it. After you do this a few times, it becomes second nature. ;)
Carlitos_92
Extremely unlikely that correctly disabling the feature via Forscan will impact the warranty.
Forscan is not that difficult. In some of the 500 threads already about this topic, the recommendation is simply to find a cheap used laptop. Forscan is not at all demanding when it comes to computer spec.
In others of the 500 threads, it is mentioned that a simple night light plugged into the 120VAC receptacle in the rear seat area will present an electrical load that prevents the A/S/S from functioning.
As mentioned above, pushing the A/S/S button when setting off is free, and no more effort than fiddling with drive modes.
hotvet67
Hogs Hollow, Michigan
2026 Ford Maverick XLT , 2006 Ford F-350 6.0 super duty , 1941 Blown Willys Coup
My 2026 must have learned I don't like start/stop
after pushing the off button for a month , has stayed off all summer in normal mode , always shows off in sport mode.
Quest
Plugging something into the trailer connector also disables
Plugging something into the electrical Trailer Connection will disable the start and stop.
Doing that will also disable the BLIS cross traffic and blind spot monitoring if you have it and your backup lines on your camera.
Lobomaniac
Central NM
2016 GT/CS 5.0 Coyote
Funny thing...I test drove a 26 Lobo the other day and S/S did not work at all. The auto brake worked at stop lights though.
They did have jump it to start it though, as it was dead from sitting on the lot too long...might that affect the S/S?
Busa789
Dennis
Iowa
2025 Lariat
It won't work unless the battery is above a set state of charge. On my F150 it takes quite awhile for the alternator to charge the battery enough for ASS to begin working again.
On my Maverick, I paid extra for ASS and it gets me much better fuel economy.
Lobomaniac
Central NM
Yeah, that explains why it did not work. Not complaining...
gjallen3
Jerry
Arizona
2024 Maverick XLT
If you don’t want to go into the console to install a by pass, there is another one that plugs into the OBD. More expensive but super easy.
WJOHNM
New York,LI
I have a 26 Lobo and it does have start/stop, I got in the habit start truck shut it off, sometimes if I make multiple stops it stays off but not all the time, depends on how long the truck is shut off. Its a pain in my a$$
Redline
Upstate, NY
My ASS stopped working a few months after I got the truck due to the battery state of charge. The dealership says it's good, but I haven't had interior lights or ASS for a couple of years now. They'll deny there's a problem until the warranty runs out, then they'll happily charge you for a new battery, telling you that you now need it. If you don't drive much, deep sleep will become the default mode for your truck. But, everything is fine. :facepalm:
Sad_Mav
Ken
Massachusetts
2025 Maverick XL AWD
I created a step-by-step guide if you want to try Forscan.
I created a Step-By-Step guide to disable A/S/S with Forscan that you might find helpful.
https://www.mavericktruckclub.com/f...step-diy-instructions-on-2025-maverick.81377/
