Auto start saves gas, vs ac compressor waste gas.
Geppetto
Holly Springs GA
2024 Maverick Lariat
Who at Ford came up with auto start to save gas and yet AC runs with AC light off. It appears AC runs based temp setting and not the AC button!
It runs based upon relative humidity and dew point temperature. To reduce chance of condensate fogging windshield as well as to prevent dew from forming on electrical things under dash. Most of time it's using air flow at foot level and under dash. When close enough to dew point it will turn on AC condenser and use the windshield and side window vents to lower humidity. If cab temp is at or below dew point all vents and air speed will be used along with AC condenser!
This can happen on a sunny day if you have several passengers panting in your maverick.
AlsMaverick
Allen
Cincinnati
2024 Maverick Lariat FX4 w/4k Tow Build Date 12/5
Are you speaking as an informed authority? Or that's what you believe?
Is this a typical operating mode for new vehicles? I'm accustomed to AC on or off, not this says it off but is still running!
You can select on, off, automatic. When off is selected it will do very little and not get cabin to set temp. Personally I would like to set heat to something like on at 60 or below and cool on to maybe 76 or higher so automatic would not run between those settings. That way humidity control could operate more freely than it does in the off setting.
I also would like to have my Adaptive Cruise Control to have a minimum and a maximum speed setting where computer could play with a range of Regen or Coast whichever is better mpg. But it does a good job holding a set speed and the range option would create road rage in traffic so it's best to pulse uphill and glide downhill in slippery mode. Remember you can push the "L" button at any speed so you can increase Regen while gliding if you want to not coast as fast and then you could set cruise to a desired speed when engine braking starts That would allow computer to determine how much hydraulic brake is needed and balance with engine braking.
Mr Pibb
Vegas
2024 Lariat
Did you push in the left knob to turn off the auto temp control?
Timothyd
I'm used to personal control with a lot of things "on/off" like the lights, the engine, the parking brake, etc.
And, how many drops of gasoline does it save shutting off the engine for a few seconds at the light.
Probably my hvb soc dropped to its restart ice point but mine seems to restart after about 45 seconds every time I have measured on my hybrid. So I wonder why restart needs to happen in no more than that time???
The Cyber Orange Guy.
Devu
Caribean
Maverick cyber orange
May the temperature is mega hot outside, that and your set internal temperature may is to low ?
paneubert
Seattle
I'm on my phone, so don't have the link to the study handy. But they found that the break even point was about 10 seconds of idle time equated to the gas needed to start the engine. So any time you are stopped for 10 seconds or more it makes sense for the engine to shut off to save gas.
Ozarkbeard
Not an issue with the Hybrid. The gasoline engine will shut off when coasting to a red light and often stay off, even when you start back up, unless you stomp the go pedal.
Exceptions are if you're running the air or heat, either of which can make the gasoline engine run at times, depending on battery charge, HVAC temp setting and outdoor temperature.
Timothyd
Now that I have a hybrid it's not nearly as annoying.
Timothyd
Since I don't race up to stop lights usually it's less than that. Balanced by the cost of a starter, betcha it's a lot these days.
