Anyone try the Bronco Sport hood insulation?
WesM
Wes
Maryland USA
I heard in one of the reviews (daily motor) that the Maverick has the same hood layout as the Bronco Sport and should accept the Bronco's hood insulation. Has Anyone tried yet? I'm curious if it would make much of a difference (quieter cabin/protect the hood from engine heat/ warms up engine faster etc).
part number M1PZ16738A
https://www.oemfordpartscheap.com/p...D/98543344/M1PZ16738A.html?partner=googlebase
Shakesbear
J. R.
Seems like there would need to be receivers on the hood for the pins to secure the insulation to???
WesM
WesM
Wes
Maryland USA
Not sure, it seems like its just held on with clips. Can someone with a maverick confirm if there seem like there are holes that correspond with the plastic insulation clips from this pic? This is a pic of a bronco sport with hood insulation.
Ford Maverick Anyone try the Bronco Sport hood insulation? 33589B51-B007-4571-8677-B424189C013D
BlackXL
Cliff
Black Hills, South Dakota
2 F-350, 2 F-250, 4 escape, mustang, bronco
Nope - you would have to drill them.
Ford Maverick Anyone try the Bronco Sport hood insulation? 7B25D3BE-14BB-482E-95A9-1031B2E831D3
Oscarcat
Eric
Encinitas California
I can confirm the slots for the hood insulator and the plastic retainer clips from a Bronco Sport DO NOT correspond/align with the holes in the hood brace for the Mav. However the size works fine and the profile of the hood insulator works, i.e. for example there is a cut out where the windshield washer hoses go from the cowl to the hood. There are two flaps that apparently tuck into slots on the Bronco Sport. The Mav does not have anywhere to tuck the flaps. The material is easy to cut with a utility knife or even a pair of scissors. I am contemplating using contact cement, two-sided tape or Velcro to fasten the hood insulator on. The consideration is heat will degrade the adhesive. I just don't want it sagging or coming loose and tangling in a belt. Or, carefully drilling holes and using round plastic pushpin style clips to hold it on. I am reluctant to drill holes due to the liklihood of rust forming on the metal. plus denting the hood because in most places you can't slide anything between the hood X brace and hood to stop the drill bit. Thoughts or suggestions?
Ford Maverick Anyone try the Bronco Sport hood insulation? Hood insulator
fossil
ernie
ohio
