I have a 2022 XL 2.0 with what appears to be a bad inner CV axle on the driver’s side. It has less than 5k miles on it. I put a Rough Country 2” leveling kit/lift on it with about 2-3k miles. The passenger side is fine. I did find some grease coming out of the bottom of the boot. It’s making a clunking noise when you rock of back and forth at low speed. It also shakes a little when I accelerate from about 10-25mph. Alignment was done a few days after the lift was installed.
I took it to the dealer and advised them of my suspicions. They stated that it was most likely the issue, but they wouldn’t cover anything as the lift voided the warranty.
I’ve seen a few things online where people are having the same issue without the lift, so I wanted to see if this is more widespread.
