Antenna pulled out from roof of Maverick. $1500 fix quoted
Goobs
Noam
Georgetown ontario
Ford maverick
Hi
I live in Canada. The Antenna of my Maverick got caught in the rope loop to pull my garage door down (See picture below). Dealer referred to their collusion expert wants. They have quoted me $1500 to fix. This doesn't seem to me that it should be that hard a fix with the right parts but I'm not sure exactly where to find them or what to do to install correctly. I was wondering if anybody here would be willing to point me in the right direction.
Ford Maverick Antenna pulled out from roof of Maverick. $1500 fix quoted 20220509_190649
MLowe05
GA
That hole looks ripped.. so for metal work on the roof, they’re probably right. Insurance will cover this. You want it to be right.
Flomounier1
Los Angeles
2022 Ford Maverick Hybrid
If the hole in the roof doesn't extend past the sides of the antenna base, you might be able to drop the headliner, rewire it, and use 3M Marine Adhesive/Sealant or another heavy duty silicone sealant to stick it back on. But you probably will never be able to take it to a drive thru carwash again.
Johnkn
MD
^^ 3M 5200 will permanently adhere the antenna base to the roof and it will be watertight. If it needs to come off in the future it will have to be cut off.
good luck....
WJOHNM
New York,LI
Hi
I ran a dealer body shop for more years than I like to admit, its a big job all labor the headline has to come down, theres welding involved so the interior has to be covered with welding blankets and seat may have to come out for easy access to back side of roof.
you're going to have to fabricate a plate and weld it in then do some bodywork and repaint roof. I did some quick numbers in my head figure about 1200 labor, materials 150 and tax
and you look like you need and antenna I would say your body shop is in the ballpark.
Sorry, all I could say is bring it to a quality shop roof repairs can be tricky you dont want mismatched or paint flaking off few year's down the road..
glider
So Cal
2002 4runner 2019 Honda civic
Probably need to drop the headliner to access the connections. Bummer
Dang, if that happened to me it probably would have pulled the garage opener down and taken out the sun roof, windshield and/or hood.
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
I would fix this with minimal effort. Touch up paint and 3M tape like mentioned. Drop the liner, rewire everything and slap it back on. Job done. Not perfect but good enough for a eco car. My 2 cents
StillWaiting
Brandyn
St pete
2009 Dodge Challenger SRT8
I would silicone and 3m tape. Drop the headliner if you want the radio connection or live off of Bluetooth
YOBY
Yoby
Pa
2016 RAV 4 / 2022 Maverick Lariat
Some would just stick it back on and go through the car wash. Just kidding.
Timothyd
Hi
Quick and dirty? Find a shark fin replacement that has a bigger base. Put it on with that 3M adhesive and rewire it under the headliner. The new antenna might even work with the bulkhead connector and you don't have to use much sealant. Grind down those edges sticking up.
snowcatxx87
Calgary
1290SDR EVO / Tiger 900RP / 300cc Grom / Surron
The emergency rope handle should be removed and zip tied anyway, biggest and easiest security threat. If there is any issue in my garage, I’m using the personal door instead of trying to open a big massive door haha.
Johnkn
MD
BTW, the 3M 5200 I referred to above is not tape, it’s a waterproof adhesive with the consistency of silicon we commonly use in the Marine field. Bed the antenna base in 5200 and it won’t come off. Worse case, there’s nothing to lose based on the existing damage
