Another Lug Nut post, with a twist
jahaas13
VT
2023 Maverick Lariat Hybrid - Cyber Orange
I've read through just about every post here about lug nuts and couldn't find the answer to my question. I have a 2023 Lariat Lux Hybrid, that comes with the 18" alloy rims. I picked up a set of stock Steel Wheels from a Maverick XL and went to swap them out yesterday and ran into an issue with the lug nuts. Specifically, the wheel cap for the steel wheels won't lock onto the stock lug nuts that came with my truck. I really want to make sure the wheel cap fits over the exposed lug nuts for our VT winters. Is my only option to buy a set of the stock lugs from Ford. That seems like a steep price for 20 lug nuts. I did find these on amazon, and the price is better. Wonder if these will work. Are there others where the stock steel wheel cover will work?
What have others done that swap out the 18" alloy wheels for 17" steelies for winter?
Hot Runr Guy
West Chicago, IL
jahaas13
jahaas13
VT
Happy Guy 823
Arthur
Dodge Dakota
I have a set I could send you. Pm me if you're interested.
Tim d
Alpena
Ram
Curious why you want to swap the wheels out for the winter,for snow tires possibly?
jahaas13
jahaas13
VT
exactly this. I live in VT and we get some fun winters. By having a second set of wheels/tires, it's easier and potentially cheaper for me to swap them out and rotate as needed.
Tim d
Alpena
Ram
Gotcha,I will be experiencing my first Michigan winter with my AWD mav on factory tires.hope it does ok!
jahaas13
jahaas13
VT
AWD and solid tires - you should be OK. My wife has a Subaru and has never had snows. I've always had FWD vehicles and a separate set of snows. Good luck
SiGmA_X
PNW
Depending on the model, the factory tires are not what I’d call solid tires lol.
STIGZZZ
New Jersey
Kia Optima/ kia Sorrento / Z06 corvette
Just a heads up going from Lariat 18" to 17" wheel and tires the rolling mass if different will mess up computer setting .... in the Corvette world big headache alot of setting have to be changed.
jahaas13
jahaas13
VT
I'm sure the mpg will be a little different, and possibly the MPH, but I'm ok with that. I think the bigger hassle will be resetting the tpms system and making sure the wheels are stored far enough away to not reset things.
What else do you think could be impacted?
STIGZZZ
New Jersey
Just going by Corvettes it would need to be re-tuned for shift points and tac would need to be recalibrated. By a experienced tuner RED line rev-limiter also for the go fast crowd..... With a Hybrid advanced computer system I would do some research
JP4AZ
Phoenix
When I switched out my stock steelies(17") to the Bronze (18") wheels on my XL, the truck did not have to be reset. The Maverick recognized the new tpm's. It also recognized the stock tmp's on the steelies when I put them back on to trade it in. Same with my CO Hybrid, no resetting of tpm's. That should be the least of your worries. The Maverick is no where near as technical as the Corvette, so noting to worry about there either.
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
Don't buy the factory lugs, contact Discount Tire, tell them you want solid lugs, not capped "pretty" lugs as they are hidden with a cover and they will hook you up with what you need. Or go on-line spend hours or daze looking.
