Adaptive Headlights For Dark Country Roads
Tmagri4
Louisa, VA
2023 XLT Ecoboost
Several years ago I had a car that illuminated the front left or right of the car when the left or right turn signal was activated. This was great when making sharp turns on dark country roads. Without them, it is often a little difficult to see where you are turning into when it is pitch black and the light is not illuminating your turning path. I would like to add this feature to my Maverick. Has anyone done this? Any ideas? Thanks.
ksc83
Kevin
Georgia
23 Maverick Lariat
My F150 has this and I agree that it’s very helpful. I was considering adding fog lights and possibly doing two sets on each side. One that would work like normal fog lights and the other that would shoot outwards some and I could manually control those for when I’m on the dark rural roads. It would be even better if I could tie them into the auto high beams. High beams on, they are on. High beams off, they are off. Either way, great idea.
In the BCM settings with FORScan there's an option for having the fog lights come on with the turn signals. In conjunction with the guide to adding fog lights it might be doable. Unsure if you'd need to replace the switch if you were to just enable them to function as turning lamps in that fashion.
fossil
ernie
ohio
Both the Escape and Sport light their fog lights depending on the turn signal position. While not as good as my 95 SHO dedicated turn lights they're not terrible.
Might be a forscan opportunity.
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
Unfortunately my Maverick XL does have "adaptive" headlights, due to poor design.
When I slow for a 90-degree turn, the headlights dim themselves automatically. I think the automatic headlights logic turns off the high beams when my speed drops below 25mph, which isn't safe when I'm driving on unlit back roads at night in deer country.
bluesteel
Jerry
Bergland, MI (U.P.)
2022 Maverick Lariat
Following this along with the other headlight thread I just bumped
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
I'm thinking of adding the Rigid D-SS Pro on top of my Keko Sport Bar, that way I can see with the side shooters. I already have them on my Honda Element and they light up the sides great!
cj99x
West Virginia
2022 RAM Power Wagon, 2022 Maverick XLT AWD RHCP
Courtesy lighting should of been a mandatory DOT requirement years ago. I can remember when Chryslers used to light an entire block with the lights they had next to the running lights on the side
Old Man
Nebraska
2023 Lariat
There's a book I found that says they turn off below 32 mph.
ThisWas
NH
RE: automatic high beams
Yes, you're right! Page 97 in my Maverick owners manual says 32 mph is the lower limit.
A Google search says that Toyota dips the high beams when my speed drops below 25 mph, which must be why I don't have this auto-dim problem in my wife's RAV4.
I'll explain to her why I need to take corners at higher speeds in my truck, for safety reasons. :D
