AC off but ON?
Srp166
Buick encore
Sometimes I'll have the AC off, the auto off and just the fan blowing, but it gets very cold just like the AC is on. Has anyone else experienced this and how do I prevent it?
OpieGoneBad
Pennsylvania
2022 Maverick XL Hybrid, 2023 Maverick XL Hybrid
Push the right hand knob (temp control) in. The center of the knob is an on/off switch. Not very intuitive. I drove around for months with the blower always running on low because I didn't see that!
Srp166
Srp166
Buick encore
Thanks, but don't want to turn off the blower, what I'm asking is using blower only but it is definitely AC cold without it being on
Srp166
Srp166
Buick encore
No, only light on is the fan. Like I said it's not all the time, guess I'll have to watch it and see what situations make it happen.
Hooverq
Rob
Wilder, Kentucky, USA
2023 Maverick XLT, 2016 Mazda Miata, 2020 E Class
I too have noticed that in my 1 week of ownership. Following
A51Mav
Jerry
Maverick XL
I’ve noticed the same situation and haven’t been able to figure out when it happens. I, too, just want vent air with no AC. I’m going to ask dealership next time I’m there.
WildHorse
Benny
DE
I'm wondering the same thing. I changed the temperature to 74 which should be higher than the environment temperature. But my AC is still blowing quite colder air.
GPSMan
Many
Yes. Yes Y'all.
To fix mine it was one of two things:
1) I cycled every single button thinking maybe one was stuck. Maybe it was, problem went away
or
2) you need to have at least one position button pressed first, either vents, floor, windshield, before pressing any other button. Maybe this solves it. I do this, problem went away.
HTH
Srp166
Srp166
Buick encore
Yes. Yes Y'all.
or
HTH
Ok, will give it a shot. Thanks
Ford Motor Company
Official Ford Account
Dearborn, mi
Hey! I can take a closer look into your A/C concerns if you like. Can you send us a direct message with your VIN and the dealership name/location?
TedTX
Ted
San Antonio TX
Not a issue with hybrids A/Cs the whole engine fires situation recall and all, be glad your staying too cool.
If the defroster in on, it will use the AC even if it is turned off.
The defroster will run when the humidity is high enough that condensate could form on windshield. The dehumidifier uses the AC!
Srp166
Srp166
Buick encore
Even though the fan is the only thing on? Is that written somewhere?
GPSMan
Many
This is not it.
You probably need to do what I said above. Select position for air first. No selection it defaults to ac on.
