A/C on even when the LED Is OFF?
23grayXLT84
Midwest
23 hybrid xlt
just keep it on auto and let it do its thing.
Deleted member 5352
Guest
I've noticed something similar on both our Bronco Sport and Maverick. I'll be driving on the highway for a little while with the A/C set on low with recirculation on and fan speed 1. All of a sudden, the car just blasts me with higher speed air until it goes away on its own or if I change the speed myself. It's weird. Maybe it's like what others said in regards to regulating humidity but since it's on two of our cars, I'm assuming it's systematically programmed. It's not a huge issue since it could be worse, it could be blasting hot air instead. But it's the just the most random thing.
Ford Motor Company
Official Ford Account
Dearborn, mi
So I was driving into work today and noticed that all of a sudden the air felt like the AC was on, like it was COLD. i had the HVAC set for face, first knotch of fan, NO recirc, NO ac, and temp set to LOW.
I did notice this happen as well on a 2020 Escape i had for a short time. I'm not convinced the system should be doing this when AUTO or AC is not selected.
Has anyone else noticed this? Thoughts?
Hello, I would like to take a look into your concerns regarding your AC. Could you please send us a message with your VIN and mileage?
FYI if you want ice to run and NOT CYCLE ON/OFF set the AC to MAX HEAT or MAX COOL! Sometimes when you pickup your truck ac may be set so. I had mine in for possible coolant leak which took over two hours. During that time the timer showed truck was on for 53 minutes and AC was still set on MAX COOL! (Did not get my 42+ mpg on that tank😂).
burger_time
MA
2007 Mazda3
I've noticed that the AC also seems to cycle on when the wipers are on. Kind of makes sense for keeping things defogged.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Recirc will build up humidity, fun fact A/C was originally designed to decrease humidity, not to cool stuff.
lance0206
New Bern,NC
15 Focus ST Big turbo 24 maverick
Mine does the same thing!! It’s quite annoying
siberdraknon
SW MI
2023 XLT Hybrid Cyber Orange
It's been seeming that way in my hybrid the last couple of weeks. I almost never use the AC and its blowing out much colder than the outside temp.
AC off, Auto climate off, recirc off, fan speed 1, temp dial set to the lowest.
Gray Goose
RG
Wissota
I spend a helluva lotta time trying to turn on or off things on this truck that the computer thinks I need to have functioning or not. Or notify me about stupid shit like the fact my seatbelt is buckled. Then I have to hit a button to dismiss the distracting warning. It certainly takes away from the enjoyment of driving this truck.
It would be a lot easier to operate this truck and a lot less distracting if it would just let me operate the controls.
Unfortunately manufacturers are putting more artificial intelligence systems into vehicles. Quite the opposite of intelligent, these systems are quite stupid. Typically if they are right at least 50% of the time they are considered successful. So quite often they are wrong. Then we as users need to make the correction for their bad decision.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
And it takes some human work and/or experience to figure out how to outsmart them.
Like auto formatting in MS Word. ARGH!
AVC
North Texas
'23 Maverick Hybrid XLT, '02 Ranger, '20 Pilot
Considering the HVB is under the truck with no cabin air flow to it, and has coolant lines for the purpose of heating or cooling - wondering how cabin cooling will do anything for it?
Besides the fact the OP has no hybrid.
What is the service info that mentions that?
Thanks
From the "free" online service manual, which includes some but not all the detail re: hybrid systems:
Ford Maverick A/C on even when the LED Is OFF? 1723240915334-n0
And this...
https://www.mavericktruckclub.com/forum/threads/hybrid-battery-cooling-data.35154/post-636532
