400w Inverter 2024 Maverick
MazuKmbero
Mario
Richmond, VA
instagram.com
'24 Maverick FX4
Hello! Can I charge portable power station Ecoflow River 2 from the 2024 Maverick inverter outlet? Battery charge fine with the cigarette lighter 100w max, but I was wondering if I can charge it faster with the outlet. Thanks!
LSchicago
Lloyd
IL
No reason you can't. I will be charging mine this way.
bgn
WA
Unlikely. Ford and most other companies install garbage modified sine wave inverters, which trip sensitive electronics. My Delta 2 trips the inverter immediately. And that's limited to 200w.
LSchicago
Lloyd
IL
Found this thread from last year on reddit, that’s why I’m asking
Well that sucks. It's the main reason I ordered the outlet.
bgn
WA
I was going to plug it in anyways, but don’t wanna risk it, truck is brand new.
You won't break anything. It's designed to trip out.
mikellmikell
Mikell
Southwest Michigan
2 Colorado's
I do 2 Ryobi and 2 weed whackers at a time no problem. I just leave the truck running. It cycles on and off as needed
WJOHNM
New York,LI
Same happens with this very small hand held vac I have on /off on off.
