120V/400W inverter standard?
Adrian
Adrian
I called Ford Motors and I asked if the 120V/400W inverter was standard on Maverick lariat and I was told that it is standard one in cab and one on bed does anyone know if th
WhoAmI2021
Glen Burnie, MD
'22 Maverick Lariat, '17 Toyota Sienna Wheelchair Van
What you are describing is the Lariat and XLT with the Lux package. The bed plug is only available with the Lux package.
Adrian
Adrian
I was told it was standard dint need luxury package is did Ford Motor Rep give me wrong info ?
adawalli
Adam
2017 Ford Explorer Platinum, 2010 Toyota Prius 3
pretty easy to check for yourself in the build tool, but not standard. It's in the lux packages
Ford Maverick 120V/400W inverter standard? 1627591288283
Adrian
Adrian
I will call again they said comes standard on all trims.
BeachFerret
Third
Not a Maverick
Is this still accurate? I ordered a ‘25 XLT without the Lux. Was hoping it came with a 120v outlet somewhere - or addable in the bed. Thanks in advance.
Only Luxury package. You can't even option the in-cab outlet as a standalone option anymore for '25MY.
Decayed
yes
a car
Unless you have a specific use - like working on your laptop while in the car, I'd skip it. Even if you do, the inverter is not a pure sine wave anyway - it made my 120v LED work light blink rapidly from the cycling and would probably be bad for electronics. I would skip it if I were to do it all over again.
You can get a better quality, higher power pure sine wave inverter cheaper from amazon that plugs into the 12 v.
https://www.amazon.com/BESTEK-Inverter-Adapter-Converter-Charging/dp/B082MDRC64/?th=1
