2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info
My 2025 paperwork, window sticker, etc. says:
  • 2025 FWD with 2.91 Final Drive Ratio
    Votes: 0 0.0%
  • Total voters
HenryFord
2025 Maverick XL Hybrid FWD(ordered)
Still waiting for my truck to be built, but I will add my info once I have it. Curious what that means for engine RPM at any given speed. Does the engine sound like it is turning a higher RPM at highway speeds in the 25?
Krazor8
Joshua
2025 ford maverick xlt
I'll answer the poll when I get home and can view my window sticker(currently at work driving my chevy spark)
SafetyGuy
Andy
Manitoba
If you have a 2025 Hybrid, please take the poll. Thank you.
Good day, The Real Maverick
I just read over your thread, grabbed my paperwork to have a look in order to contribute to your data, but my window sticker and purchase info has nothing on it regarding the final drive ratio...and it is awd. I see the drive shaft and everything! ;-)
I di take a pic of the rear end data stickers but can't see any final drive ratio...so I added my Pic in case I am being a bit thick this evening.
Anything I can look at to try and figure this out, let me know as I don't mind helping you out.
Andy
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info 20250519_194947
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info Screenshot_20250519_194508_Gallery
MarkLally
Carthage NC
2025 XLT Maverick hybrid AWD, 4K tow, 2019 Ranger
There is no tachometer to verify this, but I personally don't detect the engine running at a higher RPM than it did on my 23 hybrid maverick. My guess is the software keeps the engine RPM's at a very similar speed as the HF45 transmission.
The Real Maverick
The Real Maverick
Jack
Andy
Ya know what? Everyone talks about it yet where is it written down? Owner's manual? Maybe. But there could be a typo.
Really the way to know for sure is to MEASURE it. With a scan tool. I illustrated how I did it.
Good point though. Hard to answer this if it's not written down!
SafetyGuy
Andy
Manitoba
It isn't as easy as when I was climbing under my last F150, checking the final drive numbers so I could make sure of the trucks tow capacity for an RPod we picked up once i confirmed.
You don't know for sure, till you can confirm the numbers, to make sure of the surplus capacity. When towing, I like lots of head room.
Online search says it is a 2.91 final drive...but I don't trust that of course.
Maybe when I put it up on my ramps, I can get under it better...where is that dang steel tag with all the info I want!
Will input data if/when I figure this out.
Cheers,
Andy
Krazor8
Joshua
Can't find it on my 2025....axle code just says 33 on the door
SafetyGuy
Andy
Manitoba
Krazor8
Joshua
SafetyGuy
Andy
Manitoba
called the dealer, they stated i have the 3.37, i have a maverick xlt hybrid fwd no 4k tow(although i did tow 3900 with it fine yesterday 50 miles)
Excellent, I would imagine all should be 3.37 (no guarantees, which is why I will check with my guys).
No one would put 3.37 in a truck rated/prepared for a lower tow rating then the same truck with a 4k pkg....ummmm...like I said, I will check as well and let @The Real Maverick know here as well.
Thanks for your update, much appreciated.
Cheers
Andy
Now back to working on my thread on getting ready for/how to set up to tow (So You Wanna Tow a Trailer, eh?).
I mistakenly started it in the Off-Topic area of this site...not the Towing section. Ah, well this is how I learn.
Krazor8
Joshua
Cheers
Andy
That thread on how to tow will be very helpful, allot of people buying Mavericks down here have no experience with towing, but want to start
SafetyGuy
Andy
Manitoba
Well thank you! It is so good to already get positive feedback....back.
If you do run into anyone that wants/need to learn the basics, please refer them.
I don't have any skin in this game either (I just said the same thing a minute ago in reference to Krown oil undercoating/corrosion protection).
I can't even remember how many I have tried to inform/help others on other trailering, boating, off-grid cottaging sites I have taken part in over the years.
I see so many dangerous towing situations most days, I stay well back so they arrive at the accident scene first...I can't fix everything. And I have a first aid kit and cell phone, just in case.
Cheers and have a great day,
Andy
Ford Maverick 2025 Hybrid Gear Ratios & HF45 Transaxle Technical Info Screenshot_20250520_114556_DuckDuckGo
