2025 Hybrid AWD engine overheated at only 450 miles
I would hate to think my Maverick was taken out by air bubbles.
I know it's a different vehicle but it was a big deal with the Smart car.
Having the radiator up front and the engine in the back was a pretty long run.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
If so the fix is simple and since you didn't excessively drive it while in that mode you should be fine - you also have the warranty so you're covered but, yeah, what a drag....
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
My guess the cooling fan was unplugged when they worked on it and not plugged back in.With the engine being stone cold it probably took 10 miles to warm up and then the Fan didn't come on. My Niece had the same thing Happen with Her Kia it over Heated after it was worked on and the cooling fan connector wasn't plugged in.
Robot-Wrangler
Robot-Wrangler
Kentucky
The fan was running when I checked under the hood.
Robot-Wrangler
Robot-Wrangler
Kentucky
The new gauges are a PITA to read, but if I'm seeing the temp indicator on the left correctly, it looks fine and totally in range.
Update: The temperature icon is red instead of its usual white though the needle is clearly in the middle of the temp zone. As shown in the photo.
Robot-Wrangler
Robot-Wrangler
Kentucky
I picked up the pickup yesterday and was told the coolant was low. When I looked, the reservoir was between MIN & MAX. I would assume the tech forgot to add coolant before I picked up the truck or failed to burp it?
I only saw two reservoirs under the hood that day, though it was hot and I was upset. One has green fluid in it and the other is pink. I put 70 miles on the truck to check it out and it seems fine now.
heady
MI
'25 Lariat
The Ford WSS-M97B57-A2 coolant for these trucks is yellow. I would not be too happy with this repair shop from the sounds of it.
22XLThybrid
Paul
York, Pa.
2022 Maverick XLT hybrid (order July 21)
Coolant should be a yellowish green in both reservoirs. I've had warranty work where the system was drained and it did take quite a while to get all the air bubbles out of it. It was several thousand miles. I/dealer topped it off. If you have two different color coolants in there, it would flag me to wonder if somebody knew what they were doing with the repair. Something was obviously drained since the factory.
heady
MI
'25 Lariat
Wonder what the chances are they did a complete flush of all the lines and passages, bypassing all the thermostatic valves to prevent incompatible coolant mixing on both systems, while simultaneously changing out the coolant to the wrong stuff in both systems for absolutely no conceivable reason...
KevCuRaoi
Kevin
Buffalo, NY
2025 Maverick Hybrid XLT AWD
Yes, looks like they forgot to burp it.
yes, I agree. Not surprising that they didn't get all of the air bubbles out.
But two different colors of coolant concerns me...... I'd have them double check that the correct coolant is at the correct level.
