2025 Hybrid AWD engine overheated at only 450 miles
Hankster
Henry
Washington
2025 Maverick Lariat Hybrid
Update: The temperature icon is red instead of its usual white though the needle is clearly in the middle of the temp zone. As shown in the photo.
Where in the owners manual is the color of the temperature icon being red or white discussed? If not why not? And yes the Mavericks' instrument cluster is just that a "Cluster......."
The Real Maverick
Jack
Ok I am confused, I own a 23 Hybrid. Does this "pointer" indicate that the temp was in the middle? Is the icon on the left always red?
Ya..... no.
No one is winning an award for THAT design.
You know what's easy to understand?
Mine.
Comes off the C at 120°F
First Hash Mark is 145°F
Where it is now is 180°F
Ford Maverick 2025 Hybrid AWD engine overheated at only 450 miles IMG_3921
HenryFord
MO
That dash "upgrade" in the 25's is a huge swing and miss... It really is bad. Yeah, if they don't burp it, it's gonna blow...
wax87
Stuart
Dallas South
2004 Avalon
Ya..... no.
Mine.
But that is SOOOO OLD School, we need something that looks cool and a lot more confusing.
MaverickNoticer
Dan
Smyrna, DE
Maverick '24 XLT
Ya..... no.
Mine.
They have to go back to mechanical gauges. It is tried and true and there was nothing wrong with them.
Car designers trying to be cutting edge and overshooting useful and reliable in their quest
HenryFord
MO
Actually the focus is cutting cost. That little LED screen is cheap and can be updated with software to reflect other things should they choose to do so. It is a cost cutting race to the bottom.
heady
MI
'25 Lariat
What Is Fail-Safe Cooling
Fail-safe cooling allows you to temporarily drive your vehicle before any incremental component damage occurs due to overheating.
The fail-safe distance depends on outside temperature, vehicle load and terrain.
How Does Fail-Safe Cooling Work
If the engine reaches a preset over-temperature condition, the engine automatically switches to alternating cylinder operation. Each disabled cylinder acts as an air pump and cools the engine.
When this occurs, your vehicle still operates, however:
  • Engine power is limited.
  • The air conditioning system turns off.
Continued operation increases the engine temperature, causing the engine to completely shut down. Your steering and braking effort increases in this situation.
When the engine temperature cools, you can re-start the engine.
Note: Have your vehicle checked as soon as possible to minimize engine damage.
WARNING: Fail-safe mode is for use during emergencies only. Operate your vehicle in fail-safe mode only as long as necessary to bring your vehicle to rest in a safe location and seek immediate repairs. When in fail-safe mode, your vehicle will have limited power, will not be able to maintain high-speed operation, and may completely shut down without warning, potentially losing engine power, power steering assist, and power brake assist, which may increase the possibility of a crash resulting in serious injury.
Ford Maverick 2025 Hybrid AWD engine overheated at only 450 miles {filename}
WARNING: Do not remove the coolant reservoir cap when the engine is on or the cooling system is hot. Wait 10 minutes for the cooling system to cool down. Cover the coolant reservoir cap with a thick cloth to prevent the possibility of scalding and slowly remove the cap. Failure to follow this instruction could result in personal injury.
When the engine temperature cools, you can re-start the engine. Have your vehicle checked as soon as possible to minimize engine damage.
Your vehicle has limited engine power when in the fail-safe mode, drive your vehicle with caution. Your vehicle does not maintain high-speed operation and the engine may operate poorly.
Remember that the engine is capable of automatically shutting down to prevent engine damage. In this situation:
  1. Pull off the road as soon as safely possible and switch the engine off.
  2. If you are a member of a roadside assistance program, we recommend that you contact your roadside assistance service provider.
  3. If this is not possible, wait for a short period of time for the engine to cool.
  4. Check the coolant level. If the coolant level is at or below the minimum mark, add prediluted coolant immediately.
  5. When the engine temperature cools, you can re-start the engine. Have your vehicle checked as soon as possible to minimize engine damage.
Note: Driving your vehicle without repair increases the chance of engine damage.
It doesn't mention that the temperature indicator lamp turns red in the manual that I can see when you're in this mode, but the pop up message gives it away to the driver I guess. The indicator pointer still shows the engine temperature and will climb towards 'H' if/as the engine overheats.
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Howdy,
I picked up my Maverick from the Ford dealer yesterday after body repairs from a minor collision that sidelined the truck for four months after only three days of use. After ten miles the truck began slowing from 55 to 36 mph. A minute later, it resumed speed. Then a warning came up on the display and it began slowing again. I pulled over, raised the hood and shut the truck off as the next message said the engine had overheated. It was only 82° F and I wasn't working the truck at all.
While waiting for the engine to cool off I called the dealer and they gave me the number for roadside assistance. An hour on the phone and being told it would be another 45 minutes before a tow truck would show, I restarted the truck and turned on the engine with no faults but a check engine light. I drove a couple of miles to a store with the AC on and the engine overheated again as I pulled in for a cold drink. I remembered in my teenage years that I could turn the heat on and keep an engine cool enough to get me to where I needed to go. That's what I did and drove it back to Ford for service.
Well gee, in four and a half months, I got to drive my truck four days and 450 miles. I'm waiting on the dealer now and have no ETA or explanation. I'm disgusted! Do y'all have any idea wth is going on with this pos?
I am so sorry for what you had to experience, but this is the exact reason I will never own an EV or hybrid, I will stick with my gasoline burning, outdated dinosaur cause I know how they work, (or supposed to). Batteries for EV’s and hybrids are out of control as far as replacement costs are, thanks to, hmm… so many reasons!
heady
MI
'25 Lariat
The message was most probably due to the engine coolant loop, there's no escaping incompetent mechanics, and replacement costs for batteries are not "out of control" - they basically don't exist. You could refurbish a battery for a few hundred bucks at most, but you won't need to.
2024_xl_hybrid b&w
Austin
NC
2024 Maverick XL hybrid
EXACTLY!
Robot-Wrangler
Robot-Wrangler
Kentucky
All I'm expecting is for this truck to commute 100+ miles to work daily, take a few long trips, haul a few light loads and not break for for a few years. Then I'll be retired and just chilling and travelling for fun.
For $40k, I hope that's not asking for too much. I'm glad that I bought the 7-year/100,000 mile warranty from Ford. I used Ford Pass Points and bought a jump starter as I expect the 12v battery will discharge or fail periodically. I used to own a '14 Fusion Hybrid and sold it to my brother last year, then ordered this truck.
FischAutoTechGarten
Peter
So the truck was not repaired properly. You were upset. Don't blame the tool, blame the fool.
Imagine being the reason your vehicle was damaged and sat only to call it a POS?
imagine how your Mav feels about you…
I don't understand what either one of you are saying and how it relates to this guy's truck with just 450 miles overheating. I'm not picking a fight... I'm just geniunely confused by your statements...
Cherokee
Op said, “ While waiting for the engine to cool off I called the dealer and they gave me the number for roadside assistance. An hour on the phone and being told it would be another 45 minutes before a tow truck would show, I restarted the truck and turned on the engine with no faults but a check engine light. I drove a couple of miles to a store with the AC on and the engine overheated again as I pulled in for a cold drink. I remembered in my teenage years that I could turn the heat on and keep an engine cool enough to get me to where I needed to go. That's what I did and drove it back to Ford for service.”
In your teenage years you likely had a cast iron block and heads.
You overheated your Mavericks aluminum block and head engine twice.
Another reason I’d never buy a used vehicle.
Your likely ok, maybe. The chance of a head gasket failure later in the engines life has been increased I would think.
I was taught to never let an aluminum engine overheat. Engine off immediately and told to not restart it until it’s fixed.
710-oil-614
Cal
2025 Hybrid AWD Lariat
OPs title is little disingenuous - like OP just purchased the Maverick and after 3-4 days and 400 miles it overheated.
The truck was damaged (in a field I believe) and then sat for 4 months before getting fixed.
There is likely something that occurred during the damage and repair that lead to overheating. It’s also not the Mav’s fault it was damaged and sat for 4 months.
Robot-Wrangler
Robot-Wrangler
Kentucky
