2023 XL Hybrid - Engine Shaking / Vibration
SoonerBrink
Joseph
Nissan Murano
I have had my truck for about a year and a half, 20k miles, and the past two days there was some engine shaking/vibration noticeable while stopped and in drive.
No engine codes, no warning lights.
It has done this two days in a row.
Maybe a bad tank of gas?
This has never happened before.
I will keep monitoring and see if anyone else has any other ideas.
There is a damper between engine and eCVT - some have been reporting it having issues from the get-go, or after some time. Meant to cut out some jerkiness as engine spins up.
So stopped and engine running, does that mean:
Was running while driving and stayed running when you coasted & stopped?
Or stopped and then engine kicked on?
It's cold out and heat called for?
Or perhaps the HVB ran down to 30% and engine kicked on to recharge back to 40%?
The engine idle speed in those cases is usually rather low, I"ve seen 1500 to 2000 rpm.
So as soon as you started to accelerate it went away?
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Will you send us a message with your VIN and your local Ford dealer? We’d like to investigate this engine shake concern on our end.
SoonerBrink
Joseph
Nissan Murano
Stopped and engine running, means engine was on and vehicle not moving when it started.
I believe it continued when I started moving for a little which but I am not 100% sure.
HVAC was likely on 68 degrees, and it was cooler than 68 degrees outside, so heat was probably being used.
I believe engine was already running when I stopped and then I noticed it when I stopped.
I don't believe this occurred right at the time a low battery threshold was reached. (I monitor this with scangauge.)
I will attempt to gain more information if it happens again.
FYI... I was also one of the first ones documenting the issues with the hybrids randomly stopping and going into park. (this has since been fixed by recall.
SoonerBrink
Joseph
Nissan Murano
Tried to send PM. If you did not receive it, please reach out via PM.
Vince
Vincent
Miami
Ford maverick
My 2023 Maverick Lariat Hybrid does that once in a while too. My service advisor couldn’t find any cause and couldn’t replicate the shaking.
ckodsi
Camille
Maryland
I have noticed the shaking last few days with cold weather
ckodsi
Camille
Maryland
My 2024 lariat hybrid, started doing that last few days with cold weather
Flamav13
Rick
Oldsmar Florida
2024 XLT Hybrid
Same here. 2024 XLT Hybrid also did this twice in last couple weeks …temps were in the 40’s both times and heat was on
ckodsi
Camille
Maryland
Of note is that I had heated seats and heated steering wheel on and dash lights dimmed as engine turned on , was around 30 degrees outside
Good point - makes sense.
DCDC Converter likely close enough to max Amps feeding the 12V system, when it threw some to the generator motor to start engine that line dropped.
Interesting load test, I've seen 30A going into 12V, but I got no extra heated things to turn on. But never tried to max it out and watch how fast the HVB drops then.
ETA - maxed out and saw 55A. briefly
I'm sure there are more 30A circuits than that though, so probably closer to good old 100A potential.
Timbits22
2024 Maverick Hybrid
I've been experiencing the same engine shaking on stops, and I can feel it through the brake pedal. I only see this when the temperature is below freezing, and when the engine temp is cold. I took it to the dealer, and they couldn't find anything.
inline_five
2023 Hybrid XLT
@The Real Maverick
I think he might have some info. I *believe* this is caused by the engine warming up on cold days running at a higher than idle RPM. It's a programming/design thing and either Ford didn't test for it during their design phase or it's a feature not a bug. As long as you don't hear a loose marble sound coming from the transmission/engine mating area, this is "normal behavior".
SoonerBrink
Joseph
Nissan Murano
@The Real Maverick
It was really cold last year and it never did this. I'll keep monitoring and see if happens again.
Vince
Vincent
Miami
Ford maverick
My Maverick was shaking with outside temperatures around 75 degrees Fahrenheit
