In answer to RupZuk.
the 20X8.5”Ravetti wheels are 38mm offset 38mm which is the same as the stock Unique wheels, so there was no clearance issue with the 245/45R20 tires. Front strut clearance is practically identical to stock. This puts the tire approximately 1.5” negative which is what I wanted to achieve.
The actual hub diameter of the Maverick measured 63.25mm. Although most wheels will use conical seat lug nuts I recommend using hub centric rings for a little better fit for any aftermarket wheels.
